Titan Attachments?
/ Titan Attachments? #2
/ Titan Attachments? #4
The 60 inch skid steer pallet forks have worked super and they have held up to the abuse I can dish out, No issues I can report.
/ Titan Attachments? #5
I own a set of their forks with the stabilizer and was surprised on how much I could get done with them. Now I know this is TBN and you get to learn from others mistakes so just don't do what I did when I got my new forks and forget to tighten them up to the loader. I broke a simple rule called "Pay attention to detail" and in the photo's below you can see I paid the price.
Any pallet forks of any brand will save your back when it comes to clearing land,trees, or just moving things around I just chose Titans to use.Clamp on Pallet Forks 4,000 lbs Capacity w/ Stabilizer Bar and in the video yes I am a Alabama football fan so all you Yankees out there can eat my dirt because the war if not over here at home.
For the last week I had my Ratchet Rake and Piranha on but ran into a huge Oak tree that needs to be moved which means time to put my forks back on. Seeing my forks are back on I might also drive up to the front yard and pick me up some down tree's that I have been putting off since the last storm.
As far as Titans go and their price they have not let me down and my back thanks them for it.:2cents:
https://www.youtube.com/watch?v=2gLyysh4Jnc
/ Titan Attachments? #6
I've 2 pair of their forks, the lighter one and the 4,000 lb pair. One for each tractor. We used them heavily in clearing about an 1/8 acre of bush and brambles. I also bought their clamp on hitch. Great bang for the buck.
/ Titan Attachments? #7
I've got 4 of their SSQA adapter plates and their SSQA weld-on brackets for a "roll-your-own" SSQA (tractor side)
All look to be very well made.
/ Titan Attachments? #8
I bought a 48" single lid grapple with John Deere QA.
They are not far from me so I paid cash and picked up in person for a pretty good discount.
I bought it as a light weight compact tractor grapple and that is what it is. I can do everything I need to do with it and have used it hard and often and it has been fine. It is sized right for my tractor. Somebody else could probably tear it up in 5 minutes if they wanted to.
I walked around their warehouse a little and the heavier skid steer grapples were indeed heavy and their pallet forks looked bullet proof.
Their service and responsiveness was top notch and I don't have any complaints.
/ Titan Attachments? #9
I've bought two sets of clamp on forks with stabilizer, one for me and one for my brother. They are excellent quality, well made, and the price makes them almost a no brainer.......shipping is free and VERY prompt.
I had one call to their 'store' when I ordered the stabilizers separately, and had a great experience with their guy.
Can't speak for their other products but based on my little experience, I'd buy about anything from them.
/ Titan Attachments? #10
I have the 4000# 48" forks and have been pretty hard on them. I max out my loader (2500#) lifting logs and prying out stumps & roots and nothing has been damaged or bent yet, actually I am quite surprised I haven't damaged them yet!! :). I also have the 3 pt bale spear I use to carry my 1800# ballast box with. Very satisfied with both and would buy again!! Also, I had no fitment issues, mine fit perfect. :)
/ Titan Attachments? #11
I have their 2k lbs forks & they work well despite abuse.
Mine did not fit right when I got them the SSQA interface was loose & out of spec (very common problem, complained about on here a bit). The SSQA pins couldn't be tightened down enough & it would rattle an inch or so if you dumped the forks forward. They quickly replied after I sent them photos complaining about it in an email. They said they would swap out the frame or give me $70 to have a local welder fix things... 20 minutes of welding on 2 pieces of bar stock fixed things & I pocketed the $70 refund.
Cheap but generally good gear & they stand by it. I hear others saying they seem to be good about making things right in addition to my experiences. I consider the 2nd part probably more important than the first.
/ Titan Attachments? #12
The only real issue with Titan is the occasional fit issue mentioned. I would buy from them again.
I ordered and quickly received a set of the 1500 lb bolt-on forks.
So far I moved a big old tree stump that needed to go for some time. I can say that these forks (which said 1200 lb on the box) are stronger than my DK45S bucket, which bent (where the left fork attached) when I tried to lift the stump before it "unstuck". I thought maybe I should get the 4000 lb forks but that would have been overkill given the strength of the bucket. I straightened the bucket by pressing the fork down against a cement block until both forks were parallel.
Delivery was very fast (Fedex) anf the folks at Titan have been very helpful and courteous.
I also ordered a stump bucket, which is still in shipment. So more to come.
/ Titan Attachments? #15
If you're a Vietnam vet, welcome home.
Army medic, 1965-1968, Duc Pho and Chu Lai region mid 67-mid 68.
/ Titan Attachments? #16
I have the forks. They are capable of lifting more than my FEL capacity and you can't beat the price. They attach well but are hard to get tight enough so they don't move side to side if bumped. I guess I should've gotten the optional alignment support for $20.
They also don't work/fit well with my Piranha tooth bar.
I used them once with my ratchet straps as additional attachment and they were more stable. Also this or chains would make the bucket less likely to bend.
/ Titan Attachments? #17
FWIW, I have a brand new set of the Titan 48" x 4000 lb. bolt on forks and stabilizer bar for sale on the TBN private ads.
Bought them for Kubota B2710 that had a pin on bucket. Used twice to move some trimmed tree limbs then sold the tractor. Columbus, Texas area. PM me if interested.
Also bought a set of Titan 48" x 4000 lb. SSQA pallet forks and their 60" extensions. The forks fit very well on both New Holland TL100A and LS XR4046HC with no slop whatsoever.
The extension work well for very large items. This is when I set the stand for my 300 gallon Diesel tank on new base.
Sent from my iPad using TractorByNet
/ Titan Attachments? #20
yup, they make all the difference.
I didn't get the stabilizer initially as there are 2 web pages, one showing the forks with no stabilizer and the other with the stabilizer. I didn't know it was available as I didn't see the 2nd page.
I called them and they gave me a break on the price and sent me the stabilizer.
Massey Ferguson Model 66 Hay Rake (A65640)
Massey Ferguson...
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
2004 John Deere 693 Corn and Row Crop Header (A66285)
2004 John Deere...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
