CK35 Kioti
/ CK35 Kioti #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
A local dealer has a leftover 2012, CK35, this is an e-mailed offer to me so I am not sure what equipment is on it yet.
Was wondering what people thought of the CK35 ?
Does it have any problems ?
I have 10 acres and it will be used for landscaping, road work using both the FEL and backhoe along with a 60" box blade.
At this time I am using an SC2450, which I found does not have a lot of lifting power. This tractor is working ok but I was thinking something a little larger.
I am really thinking on a Yanmar 424 or the Mahindra Max 28XL but this one just cropped up so I thought I would ask for your help. The Ck35 appear to be close to the same tractor as the 424 but the Max28 has it over both on the FEL lift cap.
Thanks for any options.
/ CK35 Kioti #2
I have a ck35. Love it. Just a fantastic tractor. Only problem is the loader lift capacity. I think it's around 1200#. For that reason I wanted to trade it in and upgrade to a DK. The kioti dealers that I spoke with showed their true colors and would have nothing at all to do with a trade.
/ CK35 Kioti #3
The Kioti CK is a great tractor but I think Kioti loses a lot of sales because of their wimpy FEL's.
/ CK35 Kioti #4
The ck series is not wimpy, it lifts plenty for it's size. I know it's easy to say, because yours lifts 1650LBs. But just remember they all have there limitations. Even yours.
/ CK35 Kioti #5
I didn't say the CK series was wimpy, I said their FEL's are. They are a great tractor, but it seems that they skimp on the loaders.
/ CK35 Kioti #6
Kioti DK40se with its KL401 loader. Lifts 2762 lbs at the pins. show me any 40 horsepower tractor that lifts more. There might be one, but I don't know what it is.
/ CK35 Kioti #7
The DK -40 can pick his tractor up! 2400 lbs is all it takes.
/ CK35 Kioti #8
I just want to see if someone can come up with a 40 horse CUT sized tractor that can lift more than the DK40se. Maybe it exists, but I can't think of it right off.
/ CK35 Kioti #9
My old Long 2360 was a 36 horse tractor and would lift a an honest 2000 lbs in its Westendorf TA25 loader bucket, but it was not exactly a CUT sized tractor either, it was really a UT tractor with a wimpy engine.:)
/ CK35 Kioti #11
Did everyone miss that the subject is the CK series and that's what I based my comment on.
The DK is a horse of a different color.
/ CK35 Kioti #12
Come on guys, he was talking about the CK series machines, not any of the others.
I agree the CK series are not any standouts in the lift capacity realm, but he did say "Kioti". :) It is all just in fun anyway... no malice intended.
/ CK35 Kioti #13
we was just poking fun at you... no harm intended.
/ CK35 Kioti #14
The Horse:D is the same color.:stirthepot:
/ CK35 Kioti #15
With the amount of land you mentioned I would go with a DK 40, The BH on the DK has more power and will dig to eight ft. When looking for a box scraper you want the heaviest one you can get, A 72" BS has more weight for pushing and for pulling.
I have the DK 40 shuttle with the backhoe It does anything I ask it to and more with plenty of power to spare.
/ CK35 Kioti #16
The CK35 is much more tractor than the Mahindra Max 28XL. The CK weighs in with out loader at 3,151 lbs. and the Max weighs in at 1819. Yanmar does not even give the weight of the 424 on their website. I was a diehard Yanmar man (old Yanmars) until I got to looking at weights and real metal. In the smaller tractors, Kioti is kicking butt. Just for the record, my little CK20s weighs in at 2100 lbs without loader. It is built like a little tank. As far as the lifting capacities, the Mahindra Max 28XL boasts a 1402 lbs lifting capacity and again Yanmar does not publish its lifting capacity. My little tractor CK20S lifts a little over 1000 lbs, and it has been great for around my small farm. I use it for every thing. The one time I did need a larger tractor, I borrowed my friends big 65 hp green tractor with loader. He thought bigger was better also, and now he regrets getting it. He is always borrowing mine to do small jobs his tractor can't get into.
The CK35 is a perfect size tractor for 10 acres. I hope you find what you are looking for.
/ CK35 Kioti #17
The CK35 is more comparable to the Mahindra 3616, also a great machine.
Check it out.
/ CK35 Kioti #18
I have a 2014 CK 35 HST. Yes, sometimes I used to wish the loader was stronger. However I have come to realize that over 1155 lbs in the loader bucket isn't the smartest thing in this size tractor. More lift capacity means more stress on the front axle and other components. The loader is plenty strong to do most tasks. If it isn't, take a smaller bite, or a different method. I feel like the limits of the loader may reduce breakage over the long haul. Just my $0.02
/ CK35 Kioti #19
Boy I agree with you worthb, I can't say enough good things about my ck35. I had a Kubota L3200. I just hated it. I wish the loader was stronger, but like you say it's designed for the tractor and is correct.
/ CK35 Kioti #20
Another thumbs up here. I have similar acreage and my CK35 has done everything I've asked of it except lift a large load of feed out of my pickup. I ended up having to skid it down a ramp, which wasn't so bad. I use it to mow ~3.5 acres of pasture with a 6' rotary mower, snow blow a large driveway and around the shop with a 6' dual stage 3-point blower, logging, putting in and maintaining our .5 acre garden, etc. Just hitting 100 hours and I am very pleased with the purchase. I am currently using it with a 6' box blade to level an area for a 20x72 high tunnel (green house). I don't hesitate to recommend it to anyone that is interested in a compact utility tractor.
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2012 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2012 FORD F-550...
2016 Ford F-450 Utility/Service Truck, VIN # 1FDUF4GT7GEA23971 (A65563)
2016 Ford F-450...
