Your towing rigs and trailers
   / Your towing rigs and trailers #1,751
   / Your towing rigs and trailers #1,752
Tow vehicle 2002 Chevy Duramax LT Crew Cab 4x4. Trailer is 2011 Gatormade Gooseneck 20 plus 5 low pro model with 48" spread axle and 22,500lbs rating. On trailer Caterpillar 277 multi terrain loader with bucket and dozer blade up front.
https://www.dropbox.com/s/9nl1tj2r9i7b84s/20140624_163734.jpg
https://www.dropbox.com/s/io2uizooe6pzcot/20140624_163650.jpg
https://www.dropbox.com/s/4qyubg243fcn0gp/20140624_163615.jpg
Nice looking setup, I have an '02 hd that's still running strong.
I also like how you used a drop box link for your photos. They pull up much better on my smartphone.
   / Your towing rigs and trailers #1,753
brought the tractor and some implements from the farm back into town for some projects
   / Your towing rigs and trailers #1,754
   / Your towing rigs and trailers #1,755
Here is the hero shot of my F150 towing my new tractor.
   / Your towing rigs and trailers #1,756
   / Your towing rigs and trailers #1,757
If I'm seeing what I think I'm seeing, you picked an iffy place to route those rear chains through the tractor. Otherwise looks nice and shiny!
   / Your towing rigs and trailers #1,758
That's what I thought too but the dealer said that is where they routed their chains. Plus, my 20' chains are way too long for this. I'm going to look for a nice D ring to stick onto the trailer pin where I can more easily chain everything up.
   / Your towing rigs and trailers #1,759
Looks great...
Don't forget to update your tractor info from none to ?
   / Your towing rigs and trailers #1,760
Yeah, get a big clevis for the drawbar -- it makes a great tie-down point for the rear (and is useful as a pulling point on the tractor -- I leave mine on all the time). I believe I got my clevis from Tractor Supply -- it has a fairly wide mouth to fit over the thick drawbar.
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
UNUSED PABREAK CM385-55" HYD CONCRETE MIXER (A57193)
UNUSED PABREAK...
2013 KUBOTA RTV900 (A57192)
2013 KUBOTA RTV900...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2019 BOMAG BW120AD-5 SMOOTH DBL DRUM ROLLER (A52707)
2019 BOMAG...
