New Kubota 5070 finally arrived
   / New Kubota 5070 finally arrived #1
LiveRoll
Irricana Alberta
Kubota M108 FWA loader, 2014 Kubota M7060,Kubota MX 5100, Ford 1500, Kubota Bx25 , Kubota RTV900, Kubota ZD331 Zero turn mower.Kubota B1200 Grey to be restored.
Just got delivery of new 7060, it spent an extra week at dealers getting "pimped" (set up for mowing) Added JD quick attach frame and JD 390 Flail and have a JD MX6 in shop for backup. Once home, added a couple of "pork-chop" aluminum tool boxes for storage, as mowing for local oil companies requires all of their space taking things, like spill kit and always need room for tools, fire extinguisher, coveralls, tow strap clevises, grease and gun etc. Basket in front is for water for fire suppression and extra fuel as I will probably need it after loading up all the other things. Only downside so far is there isn't enough floor-space in the cab compared to My M108, so I have to look for a smaller version of the most important thing, the cooler for My lunch!
The toolboxes are mounted to loader frame posts and take about 30 seconds to remove, 1 big flat washer and 1 lynch pin and the basket the same slides in on receiver tube I had mounted through weight plate.
Thanks guys!!
Cheers
Roger
   / New Kubota 5070 finally arrived #2
your tractor is rigged up nicely.
   / New Kubota 5070 finally arrived #3
Those front tires are very nice. What type are they?
I believe they are Mitas brand, not sure on size but will get that for you.
Cheers
Roger
   / New Kubota 5070 finally arrived #5
Very very nice
   / New Kubota 5070 finally arrived #6
Very nice, I like the tool box on the loader mount idea.
   / New Kubota 5070 finally arrived #7
Beautiful machine.:thumbsup:
Off to work for it today, the big "trial run" perfect location, nice and flat for the most part, but a big fairly steep berm to mow over. Grass is already headed out so almost a foot tall ( this is a landscaped area, they tend to leave things to the bitter end) but should be able to fine tune set-up the mower. I'll get some more outside pics of the tractor today.
Cheers
Roger
   / New Kubota 5070 finally arrived #9
Really nice tractor.:thumbsup:
   / New Kubota 5070 finally arrived #10
Very nice!
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
