jlyrintzis
I'm a city boy, who a couple of years ago bought some acreage, and I also bought my first tractor last fall (Kubota B2310). I'm a total newbie when it comes to tractors, and I'm not mechanically savvy. I have a Land Pride RCR1248 brush cutter, which worked just fine last fall, but now that I tried to use it for the first time after winter, the blade doesn't rotate at all, even though the driveline is rotating on the rear-PTO. After doing some online research, I found out that it has either a shear pin/bolt or slip clutch to protect the gear box. I'm hoping that the culprit is one of these instead of the gear box itself. But how can I tell, which one I have (shear pin or slip clutch) ? Do you guys have any suggestions on how to tackle this ? Thanks in advance.
