Are all sub compacts essentially equal?
/ Are all sub compacts essentially equal? #41
I had the chance to see a J2020 some months ago and posted some photos. Can't remember the thread title right now. The LS may be nearly identical in dimension but when sitting on it, it feels much bigger than a JD 1025R.
I think it was the Boomer 30 that I sat on and I can tell you that is a much larger machine. It just did not seem as nice as the Kubota or the JD...or even Mahendra....I can't put my finger on what it was but it just seemed cheaper somehow.
/ Are all sub compacts essentially equal? #42
I am not sure that is the word I would use. And right or wrong that is one reason I liked Kubota...I know who made the thing. Yea I know brands get relabeled all the time, I just don't like it.
They are all the same aren't they. Especially those D's! ;)
I was very close between Kubota and the Mahindra I finally chose. Weight and the beefer frame was a big choice for me. Like what was said earlier, a little extra safety/stability.
/ Are all sub compacts essentially equal? #43
The Boomer 30/LS G3033 is definitely larger, and quite a bit heavier. I don't recall how NH markets them, but LS says the G series is their "basic" tractor, so it's reasonable to expect it won't be as polished/refined as what you'd find from other brands/models of similar size.
/ Are all sub compacts essentially equal? #44
I want to say that the Boomer 30 is NOT an LS G series. The G series are the small NH WorkMaster tractors. I think the Boomer 30 is unique to NH, in that it's a Bonner 35 (LS R3039) with less HP. LS has slightly more models available now
/ Are all sub compacts essentially equal? #45
The LS G series and R3039 appear to use the same size frame (66" wheelbase) and weigh about the same (within a hundred pounds or so if memory serves me). The Boomer 30 seems to have some features of both...with a different (CNH) engine. :confused2: The WorkMaster 35 does appear to be the same as the LS G3033.
Either way, the Boomer 30 is a much bigger platform than the smaller Boomers that are J series LS models.
/ Are all sub compacts essentially equal? #46
OK So the 99% use piece would be mowing the lawn, maintaining a 275' gravel driveway and moving "stuff" around with the FEL for DW who loves to garden but needs help with the heavy stuff. The extreme projects would be clearing downed pine trees (with the help of a chainsaw) digging drain lines and clearing brush from our 2.5 acre hill.
Best
Chris
Sounds to me like a Kubota BX25D would be a good fit. The backhoe will come in handy for digging drain lines and digging out pine stumps.
Or, if you're really flush with cash, the Kubota B26 is the next step up in size, capability and price.
Ok, now everyone else can resume the urination olympics about tractor specs.
I test drove a BX25D the other day. It did drive nice on the blacktop but I am not buying it to keep it clean, I have a car for that job.
Best
Chris
/ Are all sub compacts essentially equal? #48
I think you should look at small compacts like the Kubota B series and JD 2000 series. They are not a whole lot more money but they are a good bit more machine. A subcompact is a little on the small side for a primary tractor that is going to be used in brush/ woods.
/ Are all sub compacts essentially equal? #49
They are not much more money, and the 3 is not much more again. But check on that backhoe attachment....one of them I know you have to crawl under the machine and take off bolts...at least that is what the dealer said. The real price difference comes in with the backhoe's....some are more then $5k more expensive then the one right below it....pretty crazy.
I think we have come to the agreement that New Holland does not have something marketed in the sub compact area. That will leave you with the others we have talked about.
And Going back to what we talked about before I really think they are all very close to the same with just a few little differences between them. I did not look at LS as there is no dealer here and (I freely admit) I wanted a big name. Yes you do pay more for it to say John Deere, Kubota on the side, but there is a bit of mind that goes with it.
/ Are all sub compacts essentially equal? #50
Well - I said this before, but going to say it again. For me it was the dealer who took the time to talk to me and answered questions and if I got answers that I felt it was BS, I am walking out the door. JD BS'sd me and they were 10 mins away.Never even bothered to say hang on , let me get back to you with right info. This tells me they are honest. Distance has nothing to to with tractor choices, its all about being comfortable in the tractor and buying one from a knowledgeable person.
TO OP- You are buying a tractor to do chores around the place and you want to be able to service it at any given time whether its maintenance or repairs with your dealer.
/ Are all sub compacts essentially equal? #51
Best
Chris
I don't think brand name matters. I chose mine for its capabilities. It is the strongest in its category for FEL and 3pt lift. Mahindra was strongest in each size, in 2012 (though I remember that wasn't the case for the backhoe, but that wasn't relevant to me). You would have to check against current models, as that may have changed.
FEL lift would matter in loading/unloading pickup/trailer, as well as land clearing, etc.
If you aren't looking to push to capability limits, then brand doesn't matter, to me.
Things to look for, include, ground clearance, joystick position, transmission range, speed, cup holder, pedal positions/comfort. Look for what is most comfortable when you use it. For mowing, using a rear finish mower makes brand less important and reduces cost by $2000, I think. For middle mount mower, brand offerings may have bigger differences.
Dealer can be important. That did influence my decision.
Best price, in my area, would have been LS.
Are you any closer in your choice? Have you selected a size yet?
/ Are all sub compacts essentially equal? #52
LS is no longer a part of LG either.. LS is a spin off.
Being a "spin off" or subsidiary doesn't mean that it isn't totally isolated from the parent company. Parent companies usually keep a tight reign on there siblings, so while LS isn't LG it certainly has the genes of the parent and to me at least, they seem to maintain a good quality mindset.
/ Are all sub compacts essentially equal? #53
When I look at tractors, the first thing I look for is ergonomics. Does it fit ME. Are the controls placed where they are easy to use. If the answer is no then I don't need to look at the other features and specs or the major one PRICE.
Finding a tractor that fits you like a good quality glove (not a $2 work glove) takes a lot of time and patience going to all dealers, sitting/driving all brands and models to finally get the choice down to 2-3 then dickering on price can be frustrating. TBN has helped a lot of folks get the dealers to their bottom line I am sure.
/ Are all sub compacts essentially equal? #54
I think t depends....distance CAN have something to do with it. I did not even look at anything more then an hour away. You also have to remember the guy that sells is very different from the guy that is going to change the oil. One JD dealer here has a fantastic parts and service department, however I will NEVER buy a tractor from them. Sales guy I talked to was a total ***.
/ Are all sub compacts essentially equal? #55
Simply untrue. Posting information like this, when you've never seen the machines in question, and haven't even taken a minute to check the stats on them does a disservice to people looking for help. You saw a Boomer 30 at a show, but that's a much bigger machine....like 1,200lbs heavier and over a foot longer.
The Boomer 20, 24 and 25 are virtually identical in size to the Deere 1025R, and several others that you suggest are "real" sub-compacts.
/ Are all sub compacts essentially equal? #56
Absolutely, and with the same family owning/controlling both companies, is probably even more likely to be the case. Bet it's hard to marry into the Koo family!
/ Are all sub compacts essentially equal? #57
To me the deciding factor in purchasing my CUT was the DEALER...I could have purchased Kubota from a seller five miles away, or NH from a seller twenty miles away, but neither shop impressed me although they had fair prices and comparable models to what I wanted. Kubota dealer looked clapped together, service area was a mess...NH dealer was a tiny place and looked very marginal...they closed a short time after giving me a quote. I rated Deere, Kubota, and NH on ten major factors, one inclusive of the dealership and the Deere came out way ahead...yes, my experience relates to a CUT and not a SCUT but I strongly advise you to stick with a major brand name.
I am not bashing the off brands because they often build good quality equipment, BUT...for a long term purchase, stick with something you know will have parts and service available down the road.
/ Are all sub compacts essentially equal? #58
My bad. On the new Holland site they have them called Compact tractors and not Sub compact tractors, John Deere calls them Sub compact utility tractors...guess that is what tossed me....so if we want to get all technical New Holland does not have a "real sub-compact"
It also looks like NH puts several different sized machines into that same bucket, where I THINK the others have them in different areas on their site.
But true I have never laid eyes on one of the Boomer 20 or 25's I guess the 24 is something that just does not exist at least on their web site and you should have taken a minute to check the stats so you don't do a disservice to people looking for info. :p
There is a New Holland dealer down the street from work....I will run down during lunch today and see if they have one in stock....I want to get out of the office anyway.
some snips from the NH web site.
/ Are all sub compacts essentially equal? #59
Ask Cherokee140 how he's doing finding parts for his JD650. If memory serves me, he was down to hoping salvage yards might have the parts he needs....maybe he can update us.
The current reality is that none of the brands discussed in this thread are really "off brands" as they've all been in business a while. People might read your comments, think "I'll stick with a big brand name" and head off to their local New Holland, or Case dealer, and buy a compact, or sub-compact, and not realize it's made by a Korean company. Or, they might buy a Deere, and not realize it's made by a Japanese company. Just buying a big name, even Deere, doesn't guarantee future parts, or service any more.
/ Are all sub compacts essentially equal? #60
JD650 update....
I found a few salvage yards that had a clutch for the 650....but some wanted north of $1000 for the clutch :eek:
John Deere no longer makes this part for a machine made in 1986....Really ticked me off, as like you would think Deere parts we all thought would be available....nope. I was told to check with Yanmar, then Yanmar told me to get with deere.
I did finally find one at a local salvage yard for only $400...it was a used part....but what are you going to do. I then went back to the dealer to order some parts for the "mule drive" the pully system under the PTO....Bearings belts and such. Finding those parts took the dealership 2 days, the mower deck and mule drive are not listed with the tractor....but they did find them. I have all the new parts installed, 2 drive belts, 1 new idle pully, and a couple bearings that I needed to press in and it all works great. The dealership really came through finding the deck drive parts. So I am belly mowing again, but OMG what a pain.
Moral of the story is Just because it is Green Orange Red or PINK it does not mean it will still be made even 30 years later. The tractors are built to last, but you might be needing a machine shop to keep everything working. The thing that really got me was the finger pointing....talk to Yanmar, but the tractor says John Deere, yea but it is a Yanmar tractor....call Yanmar...No we don't have parts for it, talk to Deere. Then in buying a new machine....this 1 series that is a Deere....but the engine says Yanmar....yea but it is a Deere....funny that is not what your parts guy told me, they told me Yanmar built it and Deere just painted it green and slapped a sticker on it....oh, well it is not that way now.
So I bought a Kubota, they make the engine, and most bits in the machine. I am sure there are sub sources in the machine, but it sure does not have other peoples engine in it.
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2006 GMC C5500 4X2 BUCKET TRUCK (A59909)
2006 GMC C5500 4X2...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A61567)
2019 Caterpillar...
2014 Bobcat T550 Compact Track Loader Skid Steer (A61567)
2014 Bobcat T550...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
