Flow Restrictor for 3PL Tilt Cylinder
   / Flow Restrictor for 3PL Tilt Cylinder #1
grich
Western Australia
JD 3032E
Hi,
I have a 3032E with JD rear remote kit(with QD) that is used to control a hydraulic tilt cylinder on 3PL. It all works well but the control is very hard to fine tune levels. It moves far too quickly for accurate setting of tilt.
From research it appears that a flow restrictor (adjustable) is the solution, is that right?
Also where does the flow restrictor(s) go in the hydraulic circuit bearing in mind that I have two sets of outlets and only want the set used for tilt cylinder to be limited.
Thanks for any help.
Graham
   / Flow Restrictor for 3PL Tilt Cylinder #2
You can put a restrictor in the line going to the cyl. Try different orifice sizes to set the flow rate.
You could put a needle valve in the circuit and adjust to suit your situation.
   / Flow Restrictor for 3PL Tilt Cylinder #3
Graham, what is the diameter of your cylinder of your side link?
   / Flow Restrictor for 3PL Tilt Cylinder #4
Doesn't matter about the cyl size, he said it was to fast,
Ways to slow the flow.
Smaller hose
Orifice washer in the tilt cyl hose fitting
Needle valve in series with tilt cyl base end
Feather the valve lever
Reduce engine rpm
Larger cyl will be slower, but is impractical
   / Flow Restrictor for 3PL Tilt Cylinder #5
Smaller hose
Reduce engine rpm
I suspect Brian asks about the cylinder diameter to help size the orifice for choking the lines. He has been an advocate of this method for quite some time and you are both correct imo.
   / Flow Restrictor for 3PL Tilt Cylinder #6
Instead of guessing what a person needs, it usually works best to get as much info as possible. ;)
   / Flow Restrictor for 3PL Tilt Cylinder #7
The orifice or restriction must also be placed in the line that prevents the cylinder from "running away" or free falling. I.e. on top link the flow restriction would have to be installed on the rod end of the cylinder.
   / Flow Restrictor for 3PL Tilt Cylinder #8
Would that still apply if one wanted to use the top link cylinder to dump a carry all?
Would the best thing in that case be to use a needle valve to have the flow when needed and be able to slow it down too?
   / Flow Restrictor for 3PL Tilt Cylinder #9
Thanks for the advice,
I think will go with the needle valve option, that will give the best way to fine tune. One question regarding the valve recommended by J_J, you mention flow control in only one direction. I assume that that would not work with the tilt option as i want the restriction to apply to both "sides" of the tilt equally?
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
BUNDLE OF 81" X 59" DIAMOND PLATE METAL SHEETS (A54756)
BUNDLE OF 81" X...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2020 ANTHEM 64T DAY CAB (A54607)
2020 ANTHEM 64T...
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
