Pressure washer sand blasting
/ Pressure washer sand blasting #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Some of us get rust and dirt, grease and oil on our tractors, and here is a very good way to clean all that up for restoration and painting and whatever.
Here is a sand blast kit for a pressure washer to do all of that above.
The sand has to come into the nozzle from above the nozzle, so I made a backpack that contains the sand.
The tube comes over my shoulder and feeds the nozzle.
Watch the video and decide yourself if it is worth while.
General Pump High-Pressure Abrasive Blasting Kit — 3500 Max. PSI | Pressure Washer Hoses| Northern Tool + Equipment
https://www.youtube.com/watch?v=kfA-IkaMRGE
Can also clean up those rusty tools in short order.
Just dry and spray alcohol to get rid if the water, and paint or whatever.
/ Pressure washer sand blasting #2
Are you kidding me, thats awesome,:eek:
I have one of those 20 gallon thingys for sandblasting,
I wonder if it could be adapted to this setup somehow.
I like the idea of, "no sand dust" flying "everywhere.
I'll be ordering one for sure, wonder what the cost is to ship to Canada, or even if they do.
Lets see some pics of your set-up, JJ...
What grade of sand do you use or does it matter.
You got me hooked on this now....:mad::thumbsup:
/ Pressure washer sand blasting #3
I've often thought about building something like this. Seems like a natural combination but I'm sure there is some reason it's not more widely used.
/ Pressure washer sand blasting #4
That looks like a really nice set-up and works well. Only thing is using the water it will begin to rust in minutes after it dries so painting will need to come quick....
The trick to using the sand blaster is to keep the sand hose on top of the nozzle.
You need the second tube on the suction end of the sand tube to let air in.
I use dry play sand that comes in bags and then filter to get the lumps out.
https://www.google.com/url?sa=t&rct...=_quJXdBdzOIQm56Ob3voVw&bvm=bv.64507335,d.b2I
I use a bucket of back pack for the sand.
You can probably make your own nozzle, It appears to use the venturi effect to simply suck in sand and mix with the water
You can do a lot of thing with this rig. Strip rust, clean cement, strip paint, texture wood, etch glass, etc.
Definitely wear eye protection, maybe hat.
/ Pressure washer sand blasting #6
Probably the speed and maybe the mess too? Wet play sand sticks to everything. My pressure pot would blast the whole side of the tank off in the time of the video. I use play sand in my pot and wait for a day with a little bit of a breeze and go to town. I never had issues with dust, the sand flies in maybe a 20ft diameter circle and that's about it, it washes into the ground after a few good rain storms. Guess if you lived in town or didn't have a sufficient air compressor this would be the next best thing. Utilize what you have.
/ Pressure washer sand blasting #7
I have a pressure pot that works great but I wonder if on heavily rusted metal 3000lbs of pressure would do better than 140.
Bill
/ Pressure washer sand blasting #8
Thank's, JJ, I'm hooked, for under a 100, it's well worth the effort of
giving it a shot.:thumbsup:
Was never aware of something like this....and it looks like its worth a try.
/ Pressure washer sand blasting #9
Dunno, I don't see commercial sandblasters using them so that probably tells you something. I just wonder why the pressure pots work better than a standard siphon feed. My guess is the pressure pot has a long time to speed the sand up and give it some momentum. A siphon blaster just sucks it up quickly and sprays it out, not giving it much time or momentum to do as much work. This is basically a siphon feed blaster used in conjunction with a pressure washer. I still like the fact I can blast my parts, take them inside and spray them right away.
/ Pressure washer sand blasting #10
The key to siphon feed is dry properly sized sand. I wonder if pressure washer creates more suction ??? I would love to hear any real life experience with this tool ? It may be worth a gamble for 100 bucks. Any happy or unhappy owners out there ?
/ Pressure washer sand blasting #11
I can use similar sized tips on both my cabinet and pot with the same compressor and the pot will outblast the siphon 10 to 1 no problem.
/ Pressure washer sand blasting #12
I've been using one I picked up at Northern Tool a few years ago. It works great, no huge clouds of dust contend with. Make sure you dry what you sandblasted right away, or it will form a thin layer of rust.
/ Pressure washer sand blasting #13
I used one of the northern tool attachments for the power washer when I was stripping my deuce and a half with CARC on it. The water kept the silica from the CARC at bay so it wasn't a hazardous material at that point. I found that using Black Diamond blasting media worked far quicker than play sand, and with the water it kept the sheet metal panels from over heating and warping.
/ Pressure washer sand blasting #14
Has anyone tried using one of these on an aluminum truck body?
Would it tend to pit and cause more problems?
Thanks in advance,
Rich
/ Pressure washer sand blasting #15
Thanks in advance,
Rich
The water method would probably have a big advantage, with dry blasting it's easy to overheat the metal and cause warpage when doing thin body panels.
It all depends on what you are removing though. Since aluminum does not rust, I assume you want to remove mostly paint and oxidation... in which case you'd want a lighter duty abrasive such as walnut shells.
/ Pressure washer sand blasting #16
Thanks in advance,
Rich
/ Pressure washer sand blasting #17
Or just soda blast it, no need for overheating, can wash the stuff into the grass if you want to.
/ Pressure washer sand blasting #19
I bought one a few years ago. It works. It is fussy with media. You also ant to make sure no water gets in the sand feed hose or you will have a problem.
/ Pressure washer sand blasting #20
thanks ishiboo and puckgrinder,
I have an early 70's Kenworth semi sleeper, all aluminum with rivets holding it together. some one painted two stripes around it, then , painted more stripes on top of them. it would be really tough to sand around all the rivets. so looking for some way to remove all the thick paint.
Frontier RC2060 5ft Rotary Cutter (A65640)
Frontier RC2060...
8ft. Metal Drag (A65640)
8ft. Metal Drag...
Carpet Cutting Table (A65579)
Carpet Cutting...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
