New member with Kubota tractor size (and model) question
   / New member with Kubota tractor size (and model) question #11
The Ford 4610 tractor is around 55 HP. If you want to go with something a little larger my I suggest a M7040 or the newer version M7060 I have a M7040 and also have a Bush Hog 296 Cutter and have no trouble cutting 4 and 5in saplings.In my experience and of my 60 years running tractors of 15hp to 160hp a little more hp never hurts and makes things a lot easier to do.That being said it's what feels rite for you but you won't be sorry with the M7040 or M7060.
   / New member with Kubota tractor size (and model) question #12
I run an equivalent Land Pride, an RCR2672 with my L5740HSTC and also ran it with my old L5030HSTC and wouldn't want to go lower than an MX5100. I've cut 3" and above, but even with a rugged machine and good tractor wouldn't want to do it every day day. They do great on 2" and under without a lot of fuss and do a good job on grass as well.
An M5140 would work really well with one, even better than my 5740 due to the bigger frame and more weight.
   / New member with Kubota tractor size (and model) question #13
The 296 is a heavy 6ft cutter. Even though it may work with 30hp at the pto, I would seriously consider 40hp at the pto as a minimum with 45-50 as ideal. Because of the weight, you can expect a front end loader or weights on the front end as a must for your tractor (unless you move up to the 7040/7060). I would look at any of the M series tractors with the mx5100, M5140 or equivalent as a minimum.
   / New member with Kubota tractor size (and model) question #14
There's the m5640sud too. Only about a grand more than my mx4700 on the build your own site. Not sure if you could find one though. If you're not cutting big stuff an MX would do the trick I bet. Or a kioti dk45 or ds4510.
Some of the dealers I've spoken to suggested the M5140 and others suggested the M7060. There's quite a bit of price difference between the two and I'm not sure if the dealers are trying to upsell me or not.
I will definitely add a loader. My Ford 4610 has a loader and I couldn't get by without one.
   / New member with Kubota tractor size (and model) question #16
I'm leaning towards a M5140. There's only a few of them left on lots. I'd rather not have to pay for the extra emissions stuff if I can help it.
I just got an M6040HDC and haven't regretted going with it so far. I didn't want the extra emissions stuff either, or the extra cost.
   / New member with Kubota tractor size (and model) question #17
I honestly think the M5140 will do everything you need to do. I've been thinking about a used one myself.
Found one dealer with the M5640. What are the differences (that matter) between it and the 5140? It's about $2500 less.
   / New member with Kubota tractor size (and model) question #19
mx5100 is pretty much the same hp an a 4600 ford.an itll pull your shredder no prob.
   / New member with Kubota tractor size (and model) question #20
M5640 is not as nice a tractor. For example it has only synchro shift between 3-4 gear, where the M5140 has full synchro 1-4 and can also have hydro shuttle.
Are the M5640 just as capable at performing the tasks you need? Probably so.
Is the M5140 worth the extra cash? IMO, yes.
2015 MACK GU713 (A50854)
2015 MACK GU713...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
