My New 4in1 Bucket Came In!
   / My New 4in1 Bucket Came In! #11
A friend of mine who runs a full time land clearing dirt moving operation told me years ago. If it is not 4 wheel drive and no 4 in 1 its not worth having. A 4 in 1 can pick up logs, dirt, gravel and do it clean no pushing a pile around. It can spread gravel better than scrape or box blade. Pull 4x4 or 6x6 or fence post out of the ground. Plus a lot more
You will love it. The only problem is once you have one and get good with it you will never have a tractor without.
Enjoy
   / My New 4in1 Bucket Came In! #12
Here is the bucket attached to the ctl. I need to figure out a setup for the hose run to keep them out of the way of the bucket, tracks and keep them from getting pinched by the cylinders/loading arms. I've seen heavy springs and the welded rod w/circle type, but I'm open to suggestion.
My tilt-tach came with a long spring, with a clamp on top to hold the hoses. I don't have any good pictures of it, but you can see it here: Tilt-Tach for Skid Steer Buckets | Berlon Industries
   / My New 4in1 Bucket Came In! #14
   / My New 4in1 Bucket Came In! #15
Richard - There are a lot of things to think about when it comes to building one. Of course there's material thickness/weight , but there's also hinge angles, cylinder length of stroke and optimizing cylinder pressure/size to machine pressure. Too much for me to think about! :laughing: You're a brave man!
The 4in1's from Bradco, CAT and a bunch of others are lighter in weight. I've used them on ctl's before and didn't want to go there with this machine. The paint on mine might not be as nice as CA's (comparable in weight), or the name brands, but we know what happens to that.
I've gathered about 50 pictures of buckets. There are several ways to go about this. I look at it as a challenge. I'll give it a try someday. Thanks for sharing your pictures, they are in my file for sure. I really like the way yours is built. Only thing I couldn't determine from the pics is how the bucket apron is built, as in what thickness, is it doubled somewhere to add strength, etc. I can see how it's built at the teeth, was more concerned about the back end where it meets the blade.
I'll get pics and thickness measurements for you tomorrow. I think that I have some info in my emails with the builder as well.
   / My New 4in1 Bucket Came In! #17
I have a W.R. Long 4 in 1. I don't know how I lived without it. It is extremely versatile and very well built. And my 7.5 foot snow plow hooks right into the aux. hydraulics on the loader arms. Well worth the investment I made a few years ago.
   / My New 4in1 Bucket Came In! #18
It doesn't look to have a bolt on cutting edge for grading while the clamshell is open like the Construction Attachments 4in1s.
How much of an advantage would it be to have that feature?
Travis
   / My New 4in1 Bucket Came In! #19
Could those hoses be shortened 6 - 8 " and still be able to fully dump the bucket ?
Travis
If you've ever used a dozer blade on a ctl for very long, you know it's marginal at best for dozing anything other than soft material, like trench backfilling. Even on a six-way, the blade is so close to the operator that you can't see the edge like you can on a dozer. That results in poor, uneven cuts and you can push more dirt with the bucket anyway. Look in any rental yard that has a dozer blade and you'll see that it does more sitting than anything. Operators use it once and don't bother to rent it again. I know I did. People think that since a ctl has tracks that it'll act like a dozer...it doesn't, it's a small track loader. Now, attach a set of wheels to a dozer blade like this Grader Attachment - Bobcat Company and it's a whole different animal. This will be the next attachment I purchase for grading out gravel roads, pads and arenas. Whichever one I choose will have detachable wings and have the ability to upgrade to laser capability.
The HR model uses a welded on 3/4" edge instead of a bolt on in this position. That's more than enough for clamping and pushing out material at the end of a run. The inside edge of the clamshell will actually get more wear from backdragging hard material and I don't see many of those edges worn out for a long, long time. In my opinion, a bolt on edge on the dozer edge is an expensive add on and not really needed on a 4in1 attached to a skid steer or ctl.
Granted, the CA bucket is extremely well built and it is prettier. But, I'm not one of those guys that complains about a paint chip or painted over weld splatter on an attachment...I'm going to use and abuse it. At $1,000+ difference, the High Rock bucket choice was a no brainer.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52128)
Adams Load Out...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
Case 580D (A47384)
Case 580D (A47384)
12 foot two person Terry aluminum John boat (A50324)
12 foot two person...
