Buying Advice How important is 4 wheel drive on MX5100?
   / How important is 4 wheel drive on MX5100? #1
zqr
Ackerman
Ford
Looking at purchase of MX5100 with a front end lift. From what I have been told really need the 4 wheel drive to fully use front lift. Adds a good bit to price of tractor so wanted to get thoughts of those that have/have not the 4 wheel drive. Thanks
   / How important is 4 wheel drive on MX5100? #2
I cant imagine not having it in my 3032E John Deere. I would have not got anything done yesterday in the snow and ice without it.
   / How important is 4 wheel drive on MX5100? #3
All depends on what you do and how you do it. I wouldn't be without 4wd when using a front end loader, FEL. You might be able to get by without it if you have 2k+ on your rear 3pt for traction. But depends on what your ground is like for traction and what you're driving into trying to scoop up.
   / How important is 4 wheel drive on MX5100? #4
I had a larger framed 2wd utility tractor with loader that weighed twice as much as the MX5100, but was only a few more horsepower.
I always ran out of traction before I could fully use the loader or the horses to their potential. It was very frustrating.
I would really advise you to get the 4wd on the MX5100 if you are getting a loader on it. From my experience you would regret not getting it pretty quickly.
   / How important is 4 wheel drive on MX5100? #5
Keep a thousand pounds on the three point and your good to go.:)
   / How important is 4 wheel drive on MX5100? #6
Get the 4wd. If you were only using it as a pull tractor you might get away with 2wd. With a loader in a modern small tractor, you need 4wd.
   / How important is 4 wheel drive on MX5100? #7
Agreed, 4 wd works well with an FEL.
   / How important is 4 wheel drive on MX5100? #8
you need 4wd drive on the mx5100 no q about it.an it sure makes running the loader alot easier.weve went to all 4wd drive tractors.prolly need to buy a 2wd drive for summer use.
   / How important is 4 wheel drive on MX5100? #9
I've driven 2WD and 4WD with a FEL, we no longer own any 2WD tractors with a FEL; several without though.
There are threads on here where people are happy with their 2WDand FEL; just not practical for us.
   / How important is 4 wheel drive on MX5100? #10
My 70HP LS even with loaded rear tires, a 2000# bush hog on the back which has much more effect than 2000# hanging next to the tractor like a ballast box will still not back up a hill with a full bucket of rock so 4 WD is needed for FEL work. I sure helps when pulling a load also when doing ground engaging work. I believe that they will pay for the extra cost in fuel savings due to better traction over the life of the tractor.
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
17102 (A56859)
17102 (A56859)
TEREX TH636C TELESCOPIC FORKLIFT (A52709)
TEREX TH636C...
2012 International Derrick Digger (A55973)
2012 International...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
PORTABLE AIR COMPRESSOR W/ GAS MOTOR (A58374)
PORTABLE AIR...
