What do you call getting unstuck using the FEL?
   / What do you call getting unstuck using the FEL? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Got my tractor high centered on hardpack snow today, and used the FEL to move it backwards several feet to free it, a technique I have never used before. Darned if I know a term to describe doing this...anybody care to enlighten me? Thanks.
   / What do you call getting unstuck using the FEL? #2
ingenuity :)
ingenuity :)
I wouldn't have thought about it, except I did read about it here....which means somebody else showed ingenuity, not me....:laughing:
   / What do you call getting unstuck using the FEL? #4
I don't know what you call it except using the tools you have been given. I used to do that a lot when I worked in mud and the front tires on my kubota were too small to get me out, dig and roll, dig and roll!!!
   / What do you call getting unstuck using the FEL? #5
No special term for the technique that I know of, but have heard it referred to as both "walking it out" and "pushing out" with the bucket.
   / What do you call getting unstuck using the FEL? #6
The technical term is Hyrdaulicalunstuckitivness.
   / What do you call getting unstuck using the FEL? #7
I think Walking It Out is the right term. And those with FEL and backhoe really can WALK a tractor out of the mud. I have used the FEL many times to get myself out of trouble.
   / What do you call getting unstuck using the FEL? #8
A close call ?! :laughing:
   / What do you call getting unstuck using the FEL? #9
Smart. Inexpensive when it works. Never that much snow here...and mud is a legend wrapped in mystery...only those ancients who had long lived relatives can remember a time before the drought. Tanks still not filled once in over 3 years.
   / What do you call getting unstuck using the FEL? #10
The pucker moment movement
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2025 CFG H12R Mini Excavator (A56857)
2025 CFG H12R Mini...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
