lostcreekranch
Super Member
- Joined
- Dec 14, 2012
- Messages
- 8,078
- Location
- Austin County, Texas
- Tractor
- NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
They don't have to be on perfectly even ground to hook up. Approach the low side to make contact first.. Get the low side hooked and start to lift when it is level start to push and slide up and get the other side hooked up.. It is pretty easy. Does level ground make it a little easier?, Yes but it is not required. As you do the hookups several times you get a feel for it.
+ another one for SSQA pallet forks. My suggestion is to go with the 48".
As far as hookup we drop all our SSQA attachments on level as possible with a PT 4x4 under the rear of attachment. This little lift improves your view when hooking up a lot. Also the bottom of bucket, grapple is not sitting directly on the ground.
Good luck with your selection.
