The mighty Kohler starts at -2F
   / The mighty Kohler starts at -2F #1
MossRoad
Super Moderator
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
The mighty Kohler started at -2F this morning.... barely. First, the key switch was FROZEN SOLID! I had to pour some isopropyl alcohol into the switch. Let this be a lesson why key switches should be mounted vertically, not horizontally in open operator station (hint-hint Terry at Power Trac). I gave it a couple shots of starting fluid before I even tried and it went ruummmp, ruummmp, cough, barf. I didn't think it was going to make it. However, after about 4-5 tries, it went POP and fired up. Plowed my driveway and neighbors. We had a brutal blizzard last night. About a foot of snow, some 3' drifts, etc... and today is brutal cold. Had to use starting fluid on the Suburban, too. Stay warm folks! :thumbsup:
   / The mighty Kohler starts at -2F #2
Congratulations!!
The marine industry makes lots of waterproof key switches, but it doesn't stop condensation from getting inside and freezing. I'm not sure that a vertical switch would stop condensate.
I'm impressed that the starter was able to turn the pumps.
All the best,
Peter
It was THIS CLOSE (imagine tiny gap between my fingers) to not starting! :laughing:
   / The mighty Kohler starts at -2F #4
It was -7 this morning in St. Louis at 8:30 a.m. Both our cars started (mine was outside all night/my wife's was in the garage). So, I am thankful. I assume wind chills are not impactful on cars --- or anything else that does not have a body temperature. It was -32 degrees wind chill this morning.
MoKelly
Keeping the trickle charger on the battery all night in weather like this, too. ;)
   / The mighty Kohler starts at -2F #6
Cold here too. I had to actually scrap frost off the windows!! Oh and it 39F now. I bet that would feel like a summer breeze to you guys.:laughing:
   / The mighty Kohler starts at -2F #7
It's -17 and my can-am ATV started with a little hesitation. The wind chill is -45. I couldn't go more than 8 mph. I had no exposed skin and the col was still too painful.
I ran the 1430 last weekend when it was 7 degrees. The engine started without too much trouble. I added an anti-gel fuel additive. It probably wouldn't have run without that. The hydraulic oil was very thick and I was very sluggish the first 10 minutes. I may get a magnet heater and put it on the hydraulic tank.
   / The mighty Kohler starts at -2F #8
It was 62 this morning in LA. BRRRRRRRRRR........ Just bone chilling cold. I had a blanket on top of my sheet when I woke up. At least it got to 76... thought it would never get warm enough for t-shirt and shorts ;-)
   / The mighty Kohler starts at -2F #9
Yesterday,here in Northern VA, it was warm enough to melt all the snow and ice from earlier. At 6:00 AM today, it was 0F degrees- windchill at -11. The generator test started easily -- very surprised. Glad that I did not have to start the PT. Definitely working from home today.
Great job, starting the PT at -2F.
It was 74 here..... inside our house, with the furnace AND woodburner going. :laughing: Its -12.5F here this morning. Something went nuts in my electrical system on my 93 Suburban when I started it yesterday to leave work. Volt meter is way down. When I rev the engine it goes up to normal, but not over normal. If I turn on the lights or heater fan full blast, it drops and I have to drastically up the RPMs. It was a fun ride home. I had to keep it in 2nd gear to keep the RPMs up enough to run the heater fan to keep the window defogged. At stop lights I had to toss it in neutral, keep my foot on the gas and turn off the heater fan. Any suggestions other than waiting until spring? :)
New CFG 680 Skidloader Pounder (A50775)
New CFG 680...
2017 FORD F-350XL SERVICE TRUCK (A52706)
2017 FORD F-350XL...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
