Loader Lifting Capacity of L 3010 with forks
   / Lifting Capacity of L 3010 with forks #1
leoball
Logan, WV
Kubota L3010
I have a L3010 Kubota with Bradco backhoe attachment and standard Kubota front end loader bucket. Was looking to purchase forks--looked at "everything attachments" 42inch fork attachment. Was curious how much my tractor front end will lift. I am looking at moving pallets that weigh less than 1300 lbs? Anyone have any info? Thanks---Leo.
Tractor has hydrostatic trans and ag. tires.
   / Lifting Capacity of L 3010 with forks #2
Assuming u have the la481...
Breakout force (lift): 1,951 lbs [884 kg]
Lift to full height (at pin): 1,058 lbs [479 kg]
Subtract the weight of the forks. Geometry will yield different capacities at different hights/load from pin.
HTH
J
Thank C4Ranch---I have the LA482-- but I am assuming that gets me in the ballpark.
Planning on lifting pallets at 3 feet or less--can manually adjust the weight if I need to I suppose, by removing product. I know pallet dimensions etc. all come in to play.
OK guys, I have found the manual for the LA 482 front end loader and have an idea of the lifting capacities. What is your opinion of the "everything attachments" 42inch forks attachment---anyone familiar with this product or have other recommendations?
   / Lifting Capacity of L 3010 with forks #6
I have 48" forks from pallet forks.com. And really like them. I ordered the front hay spear attachment and added the forks, IIRC it turned out cheaper that way. I've lifted 1.3k lbs of deer corn, deer blinds, well houses, 600lbs of wild hog easily. IMO, they're a solid product. I'd do it again but maybe get 60".
   / Lifting Capacity of L 3010 with forks #7
Leoball, are you going to attach the forks to your bucket (bolt on, or do you have a quick attach?
   / Lifting Capacity of L 3010 with forks #8
The PalletForks.com 36" ($474) are 4"x1.25" and 300lbs. So keep that in mind if you are conserving lift capacity. The EA 42" ($656) are less at 240 lbs but are only 3"x1".
I currently have the standard bucket attached. Was looking to buy the quick attach that "everything attachments" shows on their video---looks pretty slick. I would like to make that transition easy and fast if possible. I frequently use the machine for dirt and gravel as well.
   / Lifting Capacity of L 3010 with forks #10
Quick attach is the way to go. I can swap bucket for forks in under 10 min....
Case Titan 3530 (A56435)
Case Titan 3530...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A57193)
UNUSED WOLVERINE...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
UNUSED PABREAK GB232 - 84" HYD GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 Skytrak 10054...
LEEBOY 400T SMOOTH DOUBLE DRUM ROLLER (A52707)
LEEBOY 400T SMOOTH...
