Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #1,911
I installed guage wheels on my rear blade so it doesn't dig into my driveway.
/ Pictures of your snow weapons #1,912
this looks better than no wheels but you are still running over the snow first. I would turn the blade around and push in reverse so you always had the traction on freshly cleared surface. I did still for years and bent many a back blade on those little raised lips like water cleanouts, curbs, etc. before I learned the hard lesson that every system must have some spring relief in it somewhere to release the strain or something is going to bend or break. When your in the middle of a storm up to your butt in snow and people waiting for you, some spring action is much appreciated. I now run 10' old meyer highway plow on the front end loader and another on the 3 point hitch in the rear. This gives me plenty of flex and at the end of a row in a parking lot, you don't even have to turn around, just put the blade on the back down and backup. Plenty of surplus hwy plows available from your state's DOT. I have out fitted 2 larger farm tractors with 2 blades each for about $150 a blade, and you can make that back pretty quick when the white stuff falls.
/ Pictures of your snow weapons #1,914
First time using the new 8' land pride plow.
/ Pictures of your snow weapons #1,916
vtsnowedin
I seldom need chains to plow snow. Only when there is a layer of ice laid down below the snow from melting then freezing, or a heavy wet snowfall with slush below.
But most of the winter plowing is with temps below freezing and no need for traction beyond the ballast box and fluid in the tires.
Chains if I head for the woods to cut trees and get logs in, but otherwise leave the tires naked. Saves on chain wear and saves a whole lot of shakin goin on. :)
/ Pictures of your snow weapons #1,917
vtsnowedin
But most of the winter plowing is with temps below freezing and no need for added chain traction beyond the ballast box and fluid in the tires. Even with the wing plow, usually don't have the tires chained up.
Chains on if I head for the woods to cut trees and get logs in, but otherwise leave the tires naked. Saves on chain wear and saves a whole lot of shakin goin on. :)
/ Pictures of your snow weapons #1,919
vtsnowedin
Ok as long as you have them in hand. I can't plow uphill on my steepest pitch without mine on so they stay on November to April. No pavement to worry about and if they wear out they wear out. Minus 2 F here this morning and snow forcast for the weekend. Saddle up.
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
New Holland WorkMaster 37 (A53317)
New Holland...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A59231)
2019 Harley...
2013 INTERNATIONAL DURASTAR 4300 (A60736)
2013 INTERNATIONAL...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
