Momtana 4940C With Turbo
   / Momtana 4940C With Turbo #1
Texasgreen
Mont Belvieu, TX
06 Montana 4940C/R4/FEL arched boom.
I've been looking at doing this for some time now. So I'm going to install a turbo on my tractor. I have bought the turbo and now I'm waiting on my parts from Caterpillar to come in. I'll post more pictures as I go along. Ask any questions. Enjoy.
   / Momtana 4940C With Turbo #2
What is the brand and model of the turbo? What is the displacement of the engine you're installing it on? Do you plan on adjusting the maximum fuel to the engine (altering the injection pump)? Have fun, mine was (is).
   / Momtana 4940C With Turbo #3
Hopefully the rest of the build will have as complete of pictures as the turbo alone :D
Good luck, can't wait to see your results!
It's a TD03-07T Mitsubishi turbo. Part# 49131-02531. This is the correct turbo for this engine and fulling set up. Yes, I'll post more pictures as I progress with the build. Still waiting on some parts from Caterpillar to have all the complete parts I need.
Just a quick update. My parts from Caterpillar have been slowly coming in. I have most everything that I need now but, I'm waiting on the oil feed line to the turbo from Cat. Their saying it will mid December before I get it. Here are just a few pics of the parts but not all are from Cat that I've received. Any questions please ask.
   / Momtana 4940C With Turbo #6
This should be interesting.
Do you mind posting the p/n’s that you will be using?
You have the Mitsubishi power plant correct?
   / Momtana 4940C With Turbo #7
Well let me show my ignorance! Just how do you know how to do this? How do you know what parts to get? The only thing I know about my diesel is it takes diesel. This is my first diesel ever so I really don't know much about them I know a little more than my last statement but not really a lot. Just curious is all mostly.
   / Momtana 4940C With Turbo #8
...The only thing I know about my diesel is it takes diesel.
Then you are definitely ahead of some. At least one of my diesel tractors came with gas in it and may have been a reason (or THE reason) why the owner sold it. Would vapor lock after the engine (injector pump) warmed up. It's a shame when a person finds these things :thumbdown:
This should be interesting. Do you mind posting the p/n’s that you will be using? You have the Mitsubishi power plant correct?
Yes, my tractor has the Mitsubishi S4Q2 engine in it. Once I'm done with it I'll try a post all the part numbers and where I bought everything from.
I've worked on rotating equipment for a good bit of time now and so I've learned about engines gas and diesel along with manual and automatic transmissions. If man can build it, then man can fix it or make it better. I'm not a low budget or red neck builder. I pay very close attention to specs and measurements. The reason I have been saying I'm buying parts from Caterpillar is because Caterpillar is using the same Mitsubishi S4Q2-T engine in their 305C CR mini excavator as did Montana did in their 4940 series tractors but, not the turbo version of the S4Q2 engine. So, I'm getting parts from Caterpillar and other suppliers to complete my project.
20711 (A50323)
20711 (A50323)
City of Lakeland (A51691)
City of Lakeland...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
