Overheating wiring harness
/ Overheating wiring harness #1
DAG1
Latchley, Cornwall
FE35
Hi
When driving my recently restored 1959 FE35 23c yesterday, there was a sudden cloud of smoke from underneath the battery compartment with a few flames coming off the top of the block. These flames quickly died out (my rush to get a fire extinguisher was unnecessary!) but the end result is a badly burned wiring harness.
The harness was purchased at the time of the restoration from Agriline who have told me that they are not aware of any similar problems with their product. Therefore, has anyone any ideas as to what may have caused the overheating? Cheers.
/ Overheating wiring harness #2
If everything has been fine for a while with all you electrics working then suddenly this then maybe the insulation got chafed or cut on a sharp edge and shorted out. Just a guess.
/ Overheating wiring harness #3
Do you have an alternator with a voltage regulator?
I have had some bad experiences with the regulators when they failed as they have a connection to full battery voltage and
are connected to the battery with thick wire(s) which can carry a lot of current.
Dave M7040
Hi Gents. Thanks for your replies. No sharp edges for the wiring to chaf on. On further inspection, the loom has melted in at least four places and rather interestingly, the positive lead connected to the ammeter is also slightly burned. The flames appear to have come from some burning leaked diesel fuel which had run back along the tachometer cable! Hence why the fire died so quickly.
I have a dynamo rather than an alternator, but take the point about the voltage regulator. The engineer who restored the tractor has stripped out the burnt harness and we have compared it with the original 'tired' one which we took out. The wiring on the original does seem a bit more substantial.
As a result I have investigated buying an exact (as is possible) copy of the original lucas harness as I understand this is more substantial than the various replacements available. Once installed, we will be checking all cable and instruments etc. for shorts.
/ Overheating wiring harness #5
Sounds like the smart thing to do and BTW welcome to TBN, sorry we weren't able to be more help.
/ Overheating wiring harness #6
Is any of the wiring harness fused ? And are the fuses the correct size, for the size of wire they are suppose to protect ?
/ Overheating wiring harness #7
Fuses fuses fuses. A properly constructed wire harness includes fuses to stop this sort of thing from happening. enough current to melt it in 4 places, should have popped the fuse! Even the wire to the starter should have a fusable link. It may be wise to hand construct a harness with larger wires, fuses and use a spiral plastic wire loom to protect the wires from chaffing shorts. These old machines have little electrical so the wire harnesses are simple enough to by hand one wire at a time.
Good luck and maybe you should think about mounting that fire extinguisher on the tractor?
/ Overheating wiring harness #8
I am in agreement with john bud, got to be a simple harness easily built and add fuses where needed.
Ahead of you on the fire extinguisher recommendation! Asking around locally and speaking to parts suppliers, consensus of opinion seems to be replace the voltage regulator regardless of the condition of the existing one and then as suggested by various TBN contributors, to make up own wiring harness. Including fuses sounds like a sensible idea, as none on there at the moment. Will see what can be done. Thanks again for all your suggestions, great to know there is a wealth of advice on the end of a computer!
/ Overheating wiring harness #10
Remember when comparing the harnesses it is about the gauge of the wire not the thickness of the wire and insulation together.. the new wire often has a clear sheathing over the colored teflon wire.. keeping that in mind it will also be thinner overall as the teflon coating is a higher heat rating etc.
/ Overheating wiring harness #11
Is your tractor 6v? Wonder if the 'new' harness was meant for 12v conversions? 6v wiring is bigger due to higher amps..
/ Overheating wiring harness #12
Also, if you're going to build your own harness and fuseblock I'd be inclined to step up to marine grade wiring. It has to withstand a harsh environment and is usually tinned copper. Ideally all connections are made with heat activated shrink wrapped connectors, which contain an anti-corrosion gel. It's not that much more in terms of expense, and is well worth it in peace of mind, and once and done results.
Yes to replacing VReg, and as suggested, make sure the wiring is rated to the voltage of the machine.
You should be able to find some marine wire sellers in your neck of the woods; after all you're on an island, no?:thumbsup:
Gents
Thanks again for all your help and comments. Decided to fit a Sparex harness as it was obvious it is of better quality than the Agriline one and therefore as good as using our own wiring. Included a fuse and tested for any shorts etc. Interestingly, as we were about to close the bonnet (hood!) we noticed a very small black mark on the underside above where it covered the negative terminal on the battery. You've guessed it, the black mark was evidence of very slight burning so it would appear the harness shorted out via the terminal touching the bonnet! Feeling like a bit of a plonker (idiot!). Have now covered the battery with rubber insulation and hopefully will have no further problems, fingers crossed.
/ Overheating wiring harness #15
After reading your last post, I,m confused. Isn, the negative post ground ? If it is, then touching the bonnet shouldn,t of been a problem. Not that it never should be touching it. Does the positive post have any black burn marks above it ?
Normally, that,s the one that should be protected from touching the bonnet.
/ Overheating wiring harness #16
I agree that the negative terminal should not cause a dead short, which is what you were referring to about the arcing to the hood. BUT, it's possible that there was enough transient/static energy at the area that the charge jumped the gap and passed from the negative side to a bigger/better ground, the hood and in the process passed the unregulated current through the harness. Whatever happened, the battery needs to be completely isolated from any metal. Be careful the posts don't wear through the rubber; personally I'd find a different way to make sure the two can't connect under any circumstances.
/ Overheating wiring harness #17
Is this a POSITIVE ground system?
Gents
Feeling a bit silly! Desperate to find out the cause of the fault and on seeing the burn mark under the hood, jumped to the wrong conclusion. As Guido455 says, it would be the positive post which would show burn marks. Would love to think Coyote machine is right as can find no other cause of the problem. Will keep an eye on the ammeter and carrying a fire extinguisher! Any other thoughts will be very welcome.
/ Overheating wiring harness #19
I'd want to find a way to make the battery fit without a possibility of a post grounding on the hood, without the rubber cover over it, if at all possible. Peace of mind and no other damage likely.
/ Overheating wiring harness #20
If you do go to the "hand construct" method for your harness and can't get big enough wire loom or if the wires just go in too many directions to make the wire loom practical you may want to consider some cable lacing cord. The product that I linked is wax coated which makes it somewhat sticky to itself and will hold in place as you wrap it around the wire harness.
There are different methods of cable lacing. This page shows a few: Cable lacing - Wikipedia, the free encyclopedia
2006 John Deere 990 (A64126)
2006 John Deere...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2018 Bobcat T590 (A64126)
2018 Bobcat T590...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
