Anybody know 4 wheelers: ATV's? That has....
   / Anybody know 4 wheelers: ATV's? That has.... #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Shopping the used market for a 4 wheel ATV. Anybody here know a model that has:
300-600 cc (approx, not set in stone)
4 wheel drive.
Manual (clutch less) or auto is ok.
Reverse.
Would also prefer a selectable differential lock. -Do they make them selectable, or does one have to choose limited slip or locked and live with it? I guess 2nd choice would be limited slip as I'm trying to prevent the lawn from getting torn up.
   / Anybody know 4 wheelers: ATV's? That has.... #2
I had an '07 Yamaha Big Bear 400 with a 5 speed shift with auto clutch. For a small machine it was a beast. Not too hard on the wallet either. I was out the door at the dealer with a set of ramps for the pickup for around $5400. I traded it to a guy a couple years later for my International 624, which in turn was traded in for my Deere last year. Once my final payment is made on the Deere, you can bet I'll be hot-footing it back to the Yamaha dealer for another one...
Sent from my LGL35G using TractorByNet
   / Anybody know 4 wheelers: ATV's? That has.... #3
Oh, and the Big Bear was selectable from 2wd, to 4wd, to 4wd lock, all four locked in, it was unstoppable.
   / Anybody know 4 wheelers: ATV's? That has.... #4
I would recommend a Honda Foreman or Rancher. The darn things are not as featured laden as some models, but they seem close to indestructible. The S models have the transmission you prefer, except for diff lock. I have had my Foreman for almost 10 years, and have never had a problem, except for replacing the battery 2 or 3 times. It does not get used a lot, but I need it-it starts and runs.
Will
   / Anybody know 4 wheelers: ATV's? That has.... #5
I think the Honda Rancher 420 4x4,is good unit for the money,not real sure if they have dif.lock but my fathers Honda Rincon 650 is a great 4wheeler,then there is also A Honda Rubicon 500 any of those...
   / Anybody know 4 wheelers: ATV's? That has.... #6
X3 on the Honda. I don't know what features the new one have but my old '06 Rancher saw it all.
I really like the electric shift, it gives you the ability to ride through deep water with your feet up on the rack and you can still shift if needed without getting your feet wet. Despite everyone saying "that's just one more electric thing to go wrong" it never gave trouble.
It has seen limited use since a RTV followed me home but still starts easy despite having at least 1800 hours on it. (The dash went out, under warranty, the first year and the new one shows ~1700)
   / Anybody know 4 wheelers: ATV's? That has.... #7
Look for a Polaris Sportsman 2 up, their Awd. Is second to none, and they have turf mode, meaning you can unlock the rear diff and not kill your lawn.
   / Anybody know 4 wheelers: ATV's? That has.... #8
Never seen one that did not have reverse. ATV's hold resale well, wouldn't hurt to check out new models while you're at it.
   / Anybody know 4 wheelers: ATV's? That has.... #9
I have a 400cc Honda Foreman with the automatic. It's a good unit. I also have a Yamaha 400ES Kodiak with the electric shift. The Honda is a bit easier to drive, the Yamaha seems to have a bit better traction. Both units are 13 years old and have been problem free although like D86 said, the ATVs haven't gotten much use since we got the TRV utility vehicle.
AFAIK, most ATV's have a solid rear axle, no slip, no unlocking. Maybe the bigger ones have rear LSDs? I don't know.
As long as you take the turns wide, I don't notice lawn damage. Maybe if it's real soft and muddy but I try to avoid the yard then.
   / Anybody know 4 wheelers: ATV's? That has.... #10
I know the Yamaha Big Bear chamged from a solid rear axle to an independent with a differential between 06 and 07. I can't speak for any others though
2022 Schulte 2500 Giant Rock Picker (A55315)
2022 Schulte 2500...
2021 GMC SIERRA CREW CAB TRUCK (A57192)
2021 GMC SIERRA...
CAT CB-54XW (A53317)
Flatbed Trailer (A51694)
Flatbed Trailer...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
1989 BOMAG BW213D SMOOTH DBL DRUM ROLLER (A52707)
1989 BOMAG BW213D...
