John Deere 2305 Compact Tractor Transmission and rear PTO failure
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #71
I didn't see your post. I was desperate to repair my tractor after "THE INCIDENT". My JD dealer, and JD customer service, FIRMLY stated that there was not a complete transmission unit available. I would have quickly paid for a transmission to be shipped to me.
When you read the tuff torque website, they state that the PTO is an option, and it doesn't show the three point lift assembly either.
I understand that ALL manufacturers use outside assemblies to complete their finished product; however, the suppliers they choose reflect their quality, so extensive product testing and a fair warranty approach are key elements to retaining good customer base faith. My faith is gone with JD.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #72
Does the 2320 also have the same week points as the 2305?
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #73
the 2320 is a 24 HP yanmar I beleieve. The big difference between the two tractors is wheel size, a hinged rops on the 2320 and the 2320 may have individual right and left brakes. Otherwise they appear to be the same tractor.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #74
Go to your dealer, and ask what he would charge to gurantee your transmission against cracking from pto or 3 point stress and watch the look on his face.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #75
Completely different tractors.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #76
Well I have just experienced the rear pto failure, using a rear tiller. I'm certain I hit a tree stump or rock, but instead of the tiller taking the punishment the pto cracked off. My 2305 was purchased in fall of 2008. I will be tearing it apart this weekend to see the extent of damage.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #77
Could I ask... did you have a slip clutch on the pto shaft? I've had the repair done and use slip clutches on everything on the rear PTO now.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #78
Also, your 2305 is it a 2008 or could it be a leftover from 2007.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #79
Did a bunch of loader work moving gravel so I was on and off of the pavement and I noticed some spots on the driveway. Took it into the dealer they thought that perhaps the gasket on the rockshaft was leaking so they replaced that, only then did they notice that after cleaning up the area that the rear transaxel was leaking and had been what looked to be epoxied. SON OF A !!!!!! 2000 for the part and roughly 3000+ in labor. Not sure what to do from here. I used mine for loader work and MMM, no rear PTO impliments. Granted I bought it at a farm auction so I'm more or less screwed.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #80
Maybe put it back in the same auction before it hand grenades?
D.
New/Unused Fuel Pump with 50ft of Hose (A57453)
New/Unused Fuel...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
