k0ua
Epic Contributor
I had nearly the same experience with Whiskey.
OMG..
Is it a Lube or a protector?
I have some stuff called Chesterton is it the same thing?
Get with it Murph ---------
You are SUPPOSED to be The Leader of The Pack.
We look up to you as all seeing, all knowing, all -------- everything.
For the life of me I can't see what the big deal is, stuff ain't but a mix of lanolin, mineral oil & paint thinner you can make yourself for cheap money.
If the math is right it's $6.65 a can when you buy twelve on fleebay. Fluid Film Corrosion Protection 11 75oz Aerosol 12 Pack | eBay
wouldn't use it up.I have been a fan of Fluid Film for years. I spray it on my gooseneck hitch about once a year.
I go through about 10 cans a year. I use it on lots of things. Electrical connections, lug nuts, fertilizer applicators, just about anything metal.
Fluid Film is a lanolin based rust/corrosion preventive and lubricant that provides long term protection and lubrication for all metal surfaces. Fluid Film locks out and displaces moisture while lubricating moving parts for extended periods of time. It will not be readily washed off with water, but creates a barrier of protection that continues to work even in the most corrosive of environments. Fluid Film is the worldwide standard for corrosion protection and lubrication.
Both John Deere and Caterpillar use Fluid Film on their heavy equipment before shipment. It sits out in full exposure to salt air, salt water, and rain, and the product continues to work for them.
You can learn more about Fluid Film, and find a dealer near you here,
About Eureka Fluid Film
If I can answer any information, please let me know. We are a new sponsor on this site, and I've become somewhat addicted in a very short time.![]()
I received an email from eBay that my case of Fluid Film had shipped. That was less than an hour after order was placed. Did a little more checking, just for grins, and never found a price anywhere close to the $6.65 even for 12 can quantities.
