Lets see your Woodworking Skills
   / Lets see your Woodworking Skills
2lane, that's nice work. The headboard has given me an idea for a project.
trout, I know the finger joint in the first box. How did you do the joint on the second box? Very nice.
Kevin, did you build the jig and steam the wood?
   / Lets see your Woodworking Skills #12
I haven't made much recently. I did make a few great projects when I went tot school for cabinet making, but I don't have a by digital photos if that stuff
This is a recent project I built for my sons first birthday. The horse body is one piece of Baltic birch plywood that was steam and kerf bent to shape.
Sent from my iPhone using TractorByNet
Very nice. A labor (labour in Canada?) of love.
   / Lets see your Woodworking Skills #13
Man!! you guys have done some impressive work, it certainly is an art form!
   / Lets see your Woodworking Skills #14
I made this. It took all day.
Cliff
   / Lets see your Woodworking Skills #15
I actually followed a plan in Canadian Home Workshop magazine. I have plenty of skills, but zero creativity and like following plans.
   / Lets see your Woodworking Skills #16
This is the headstock of an acoustic archtop guitar that I completed several years ago. Note that it is a seven string.
Edit: Also note that the Koa does not appear to be bookmatched but it actually is.
   / Lets see your Woodworking Skills #17
The ends are joined at 45 degrees then slots are cut into the corners using a jig which holds the box at 45 degrees to the table saw. I insert a small slice of contrasting wood into the slot and sand it down to form "keys". Thanks for the compliment.
http://www.goldfinch-acres.com/Exotic Hardwood.html
   / Lets see your Woodworking Skills #18
I got nothing to share here, I am way too sloppy for that kind of work - except the shavings. I can make shavings with the best of you :D
   / Lets see your Woodworking Skills #19
So I guess this is as good a place as any to ask.. what router bits do you use? I was looking for some rail/stile and raised panel bits and came across what I thought were good ones- I think they were eagle. Anyone have experience with these? They were pricy but seemed good, and made in USA which is important to me.
   / Lets see your Woodworking Skills #20
Man, you guys are good...
The roof rack crossmembers are shaped like airplane wings (I know, hard to see, best I can find on short notice), the knife is an experiment recycling a broken pair of scissors, the canoe is 17 1/2 feet long (western red cedar hull with ash and red oak frame work). I also have pics of a shorter canoe which I can't find right now.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2013 Ford F-150 (A50397)
2013 Ford F-150...
New Holland HM236 3pt Disc Mower (A50774)
New Holland HM236...
71062 (A49346)
71062 (A49346)
