Would you allow this person to operate your equipment or work on your site?
   / Would you allow this person to operate your equipment or work on your site? #2
No, I'd let him bring his equipment over to do it. I'd be the guy with the camera uploading it to youtube for everyone to laugh at. Not sure I could keep a straight face long enough to hold the cam steady. It's a good thing he owns a tripod.
Good tip for Mr. Weatherford: Bob, if bouncing and rocking in the seat is required to have enough traction and power to pull, you're pulling too much.
   / Would you allow this person to operate your equipment or work on your site? #3
Why do people go to all the work and trouble to dig up stumps? You can drill a few large hole in top, soak stump in diesel, wait a day, and light it on fire. Most will burn for days and you end up with a hole in the ground full of ashes. If this is just going to be pasture, makes life easier.
The only reason I see to remove a stump was if you panned to plow area up for planting. Even then most stumps burn way down into the ground.
My 2 cents worth.
   / Would you allow this person to operate your equipment or work on your site? #4
If you want to pull stumps, use a tractor and not a lawnmower.
   / Would you allow this person to operate your equipment or work on your site? #5
If you want to remove stumps, cut them off the tree after you used the tree as leverage to take it out. Saves hours trying to remove something you shouldn't have left in the first place.
   / Would you allow this person to operate your equipment or work on your site? #6
Imagine what this guy would do with a D9 dozer
   / Would you allow this person to operate your equipment or work on your site? #8
This guy is the reason i bought new. I feel sorry for his equipment
   / Would you allow this person to operate your equipment or work on your site? #9
This why I'm leery of getting used equipment. LOL
Wedge
   / Would you allow this person to operate your equipment or work on your site? #10
When big ideas meet a small budget.
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
2009 International Workstar 7500 T/A Terex Commander C5045 Digger Derrick Truck (A55973)
2009 International...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
