Matching a trailer to my load/truck, current setup isn't cutting it????
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #21
DEPENDING ON IF YOUR REAR HITCH IS RATED FOR THE WEIGHT....A PINDLE HITCH-BUMPER PULL TRAILER WILL HANDLE A LOT OF WEIGHT! YOU CAN PICK THOSE UP CHEAP AT AUCTIONS FROM UTILITY COMPANIES OR GOVERNMENT AUCTIONS. THEY ARE USED TO HAULING BACK HOES, SMALL DOZER'S ECT. BEHIND DUMPTRUCKS. WE ALWAYS USED THEM AT A UTILITY COMPANY SO WE COULD PULL WITH BUCKET TRUCKS-THEY HAULED DITCHERS AND BACKHOES. BUT A GOOSENECK IS PROBABLY THE BEST BET-IT WILL DISTRIBUTE THE WEIGHT, EASIER TO TURN IN TIGHT PLACES AND A GOOD USED ONE WILL BE JUST AS MUCH AS A NEW BUMPER PULL. CHECKING ON CRAIGSLIST-A 36' 4 YEAR OLD TRAILER-2-10K OIL BATH AXLES WITH DUAL TIRES FOR $3700. THATS A LOT OF TRAILER TO PULL IN TRAFFIC AND THRU NEIGHBOR HOODS!
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #22
Go with a 30' gooseneck and you will never look back or want a bumper pull again. I have a short bed f350 and there are no issues pulling a goosneck. Don't get 7k axles you need 8k or larger if you go single wheel gets load range g or 17.5 well worth the extra money.
I have pulled my set up with older f350 and current 12 f350 and my 97 f450 all do fine up to about 22000 on the trailer as I run out of trailer tire.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #23
Is a Class 5 hitch and WD hitch, easily retrofitted to my truck? How much would something like that cost?
Weight distributing hitches will work on about any hitch receiver. You also need room on the trailer front rails for the connectors for the spring bars. This setup is normal and common for anyone with a bp travel trailer.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #24
You can get a Reese Titan hitch for about any 3/4 ton truck up. They will easily handle the tongue weight you want.
Chris
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #25
Rusty, have you used both? The reason I ask is because my current trailer is a dovetail with fold up ramps and I hate it. I know it isn't good to hang the rotary cutter off the end but I would love to be able to let it overhang a few feet, whereas now I can't, because the ramps are always in the way. I haven't used a flat deck trailer but I can't see why it would be a big deal. I would really only use it for equipment, and not a car or anything that needs a shallow angle of approach. I feel like I would get more usable space with a flat deck.
The other use I have for the trailer, is to lay my Woodmizer sawmill on it for when I want to do a mobile job. The mill is not a trailerable model (LT 15) but is easily setup on a trailer. I've done this on my current setup but it overhangs as well.
I also do not like how little clearance I have on the back of the tractor, more than one occasion I have scraped/dragged the bottom of the trailer on a customer's driveway, I have to be really careful of that.
I'm browsing online and found this PJ trailer...
PJ Trailers - 8" I-Beam Deckover (F8)
I would probably like the 26' model, it comes with two 7,000lb axles and has a 14k lb weight rating. The trailer weighs 4k lbs (actually 4300 but let's say 4k for easy math:D) I'm assuming this means I can safely and legally carry 10k lbs?
If I were to upgrade to the two 8k lb axles, could I then legally carry 12k lbs on the trailer?
What would be better, two 8k lb axles, or three 7 lb axles? It seems like 3 axles would weigh more, and I couldn't take advantage of the extra weight rating, but it may ride or carry the load nicer with 3 axles? What are the advantages and disadvantages of 2 or 3 axles?
Just keep in mind you're considering changing 2 things from you current setup that will effect loading. Deckover=higher, steeper load. No dovetail = steeper again. Personally I prefer a dove on a deckover.. If you want to spend the money there are options like pop-up doves, fold-over wedge ramps, pop-up center sections that try to give you the best of both. If you go with no dove you will need the longest ramps, which can get heavy for sliding in. Commercial for-hire haulers like straight decks because they want to have every inch available for a paying load.
Tri-axle 7K's versus two 8K's you will get a lot of opinions. Tri-axle = 2 more tires to maintain but they are a lot cheaper than the 17.5" tires on an 8K. Tri-axle can put more stress on axles/tires/wheels with sharp turns. Tri-axle should definitely give you higher capacity/GVW. If two 8K's can cut it for your loads, then go with that, otherwise consider the tri-axle. Extra weight of 3 axles, eh, maybe a little. Remember everything on the 8K's is heavier, axles, hubs, tires, wheels, so could almost be a wash.
I don't know if you're concerned about your total gross combination wt. Some guys like to stay under 26K because of CDL requirements. In that case a 16K trailer and 10K rated truck works out OK. If that's not a problem we can spend your money and tell you to buy a tandem-dual. Pay attention how trailers are rated. Some manufacturers include the tongue weight in the MGVW (ie. two 7K axles and MGVW is greater than 15K. Others do not do this, that is 2 7K axles and they rate the trailer at 14K. I suppose legally and technically you should not exceed the max specified on the trailer's frame tag. Does it matter?, depends on enforcement in your locality.
If you decide to have a bumper pull built tell them you might be using a WD hitch and want to have that part of the front A-frame clear for the brackets or plates. Things like breakaway batteries, tool boxes, chain trays, cross braces, etc can get in the way.of the WD stuff.
If you decide to go BP, keep an eye on your receiver for rust and cracks, etc. Maybe best to replace it with a nice heavy rated Reese or Curt like Chris suggested and have piece of mind. Good luck whatever you decide.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #26
Does anyone have experience with a weight distributing hitch off road on farm land?
My use was on a RV pulling a horse trailer.
Where we used to live, the hay field had terraces big enough that the trailer would drag the ground.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #27
I agree a longer tri axel is the way to go. With the long loads hes hauling it makes keeping the axel weights much more manageable.
Your comment about the CDL may be a little off the mark, anytime the trailer by itself is 10,001 or greater the 26,000 gvw is no longer valid.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #28
I thought the trailer weight is state by state. I'd go dual tandem over a triple axle anyday. If all your doing is straight than it'll work but start getting into tight areas and its just dragging that rear axle all over the place. Also it is more to replace tires on but Ill take 8 over 6 for heavy loads.
Brett
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #29
So just to make sure I understand this correctly, the tongue weight load does not apply to the total weight on the trailer? So if I have a 16k lb trailer, and it weighs 4k lbs, I can load MORE than 12k lbs on it legally?
in short yes.
The axles are designed to hold 16K. if you scale the trailer only, youll find that you have less than 16K on the trailer axles. If you have less than 16K on the trailer axles your are legal. The next question is is your GCWR is under your tow rig maxium, and or have you exceeded the GAWR for the rear axle. If both of those are also true, you are legal with with more than 12K of cargo on a 16K trailer that has a curb weight of 4K. (by the amount of weight you transferred to the tow vehicle via TW)
Thanks for all the really great advice so far regarding my towing needs. The more I think about it, the more I think I'll want to stick with a bumper pull. There is a really good chance I will purchase a new truck in the next few years and I plan to add a cap to the bed, which I could not do with a GN.
Based on my pictures/explanations, would you guys agree that 26' would be sufficient for my needs? Would it be a good idea to go with a 28' if the price was not too much more? Typically the longer trailers tow nicer and with the extra couple feet I may be able to balance the load better. However, I don't want it to get too long either.
If I don't need the rotary cutter when I do a job, I'm all set with even a 24' trailer, however the times I need the rotary cutter I can really use that extra space.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
(INOP) MASSEY FERGUSON 543 TRACTOR (A59823)
(INOP) MASSEY...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
