Share your Mahindra experience.
/ Share your Mahindra experience. #1
Aravind
kerala, India
none
Hi everyone,
Please Share your experience with mahindra tractors, its operating patterns, which model u use?....
/ Share your Mahindra experience. #2
I like mine and it works for me, enough said.:D Model 5010HST. :thumbsup:
/ Share your Mahindra experience. #3
Our 2810 gear has held up well, and gets used pretty hard by multiple operators. Only issues we have had is leaking seals (both front and rear wheel/axle seals, and PTO seal) but once I learned the RTV trick from a dealer here, I haven't had any more leaks so far. I also suspected the rear axle seals were installed backwards from the factory.
Also have had sticking solenoid issues both the PTO and fuel shut off solenoids.
The gear selector linkage (1-4 gears) has broken twice now in the same spot. This could possibly be because of operator, or linkage needs to be beefed up.
Other than that I have been impressed. On a side note I think it would be nice to see coolant filters on mahindra's, even if just on the larger utility/cab tractors. They really help keep the cooling system in good shape.
/ Share your Mahindra experience. #4
This might be hard, but I would also love to see the battery and/or air filter relocated somewhere besides in front of the radiator. it sure would make routine service easier.
/ Share your Mahindra experience. #5
30 light-forestry hours on my 3016 and 99.9% of everything is A OK.
Metal to rubber wear indications on the FEL hydraulic lines so I wrapped them with 3/4" heater hose and zip ties.
/ Share your Mahindra experience. #6
I have two, a 7520 4x4 and a 3215HST. Both tractors have loaders and have been excellent machines for what I use them for around the ranch. ;)
/ Share your Mahindra experience. #7
I have the 5010 cab /gear model, no complaints thus far.
/ Share your Mahindra experience. #8
My 5035 HST has been nothing but problems. I can't put chains on it in the winter because it is so heavy/has so much traction in 4x4, it doesn't really need them. I can't use the seatbelt, I find myself standing sometimes and working the HST go pedals with my toes... inching stuff around with the forks.. I can't beach about mowing around stumps anymore, 'cuz someone dug them all out with the backhoe. Can't converse with the neighbors much anymore... all they keep muttering is " geez, that's a BIG tractor". Yup, nothing but problems... [ :) ]
/ Share your Mahindra experience. #9
Those are the types of problems that most of us would enjoy having. :thumbsup:
/ Share your Mahindra experience. #10
2002 Mahindra 4500 2wd, no FEL. 450 hours and hasn't ever has any issues. It's used to bush hogging yearly and planting food plots for deer hunting.
/ Share your Mahindra experience. #11
My 2010 5035 has been awesome. Like most other 5035 owners, you will never hear me complain about not enough power for any job.
I highly recommend my dealer, Lott Enterprises in Claxton, GA. Service and support have been top notch.
/ Share your Mahindra experience. #12
Well, I'm gonna have to agree with brother Jerry.;) My Mahindra 6520 4WD with backhoe takes so much of my time, I can't get anything done off of the tractor. Like cleaning house and visiting friends.:eek: I am always looking for ways to use my Big RED Beast more and more.:) That is bad also as I am always searching auctions and buying more and more toys to attach to it.:eek::eek: Toys that weigh lots and lots of pounds and need more room on my trailer. Which makes me want a longer trailer, that is only 11 months old. Oh the visious cycle.:shocked: Where does it all end?:confused2: hehehe. I love my Mahindra.:licking: Best investment I ever made.:thumbsup: Well, besides buying trucks with Cummins in them.:cool:
hugs, Brand
/ Share your Mahindra experience. #13
I have a 2516 that gets used for wood hauling/dragging and food plots, no problems yet!
/ Share your Mahindra experience. #14
Mahindra 5530, 2wd, FEL, and 6 foot bush hog. Only 11 hours so far, but LOVE it! Big, heavy, powerful tractor. I am having a smoking issue, to much white smoke from exhaust, but I have contacted the dealer and they are being very helpful in getting it solved. Being the week of the 4th their service tech was on vacation but they said they would contact me Monday to get it handled. As I said though even with the smokeing issue it has done everything I've asked of it. I went from smaller compact tractors (27-32hp) now up to a 55hp full size utility tractor and will never go back. As many have said on here, decide what size you think you need and go one size bigger, you wont be disappointed. Thanks, and good luck!!
/ Share your Mahindra experience. #15
3215 4WD with fel. A little over 400 hours and it has done everything I have asked of it. Just finished baling 10 acres of hay with it. It did a great job operating the MF Dyna balance sickle mower, pulling the hay rake, and took care of business with the IH 37 square baler.
/ Share your Mahindra experience. #16
3616 shuttle, only problem was an alternator issue about 10 hrs, new alternator installed by our dealer no questions and another owners club hat in the mail several weeks later. Only cost me $1000 for a box blade.
The tractor does all that we have asked so far with no other issues. Sure love the quick change bucket on ours, best money ever spent, I can change from bucket to pallet forks faster than I can drive to the the storage area. I will be modifying the brush cutter hookup to a sliding pin from a stud pin to ease the changing if implements. The 72 inch brush cutter is a lot harder to move a little for lineup than the old 42 inch one on our old Yanmar.
Cam
/ Share your Mahindra experience. #17
8560 4 wheel drive. 147 hours on it total. 100 hrs brush hogging blackberry bushes and over growth. Put up 395 5X6 round bales so far. Dug out a 2 foot deep pig wallow to 12 feet deep and 70 feet wide. that was a muddy blast!!! Put in 20 fence post. Dragged the 1/2 mile drive way twice. Not on problem yet except I should of listen to the wife for once and got a Cab...LOL. this is all on my 80 acre cattle ranch that has been neglected for 10 years. Mahindra was the best tractor for this job!
/ Share your Mahindra experience. #18
Check your loader bolts. On my 7520 they were all loose at less than 100ft# when delivered. Two that were hard to find were finger tight. Some on the subframe also needed washers to shim for a neutral fit up. Get em right and theyll stay tight.
- I have about 1000 hrs of loader work out of 1200. A strong platform. The front driveshaft twisted off and later the left halfshaft at the front knuckle. Re the latter, I have the old weak power steering and sometimes the wheels will cock to the lock in a hard push on uneven ground. Now I stop and straighten them before continuing.
larry
/ Share your Mahindra experience. #19
I read on this site about checking the loader bolts. So it was the first thing that I did when I got her home. Had 2 that were loose. Thanks for the tip. Should be a sticky on this subject..
/ Share your Mahindra experience. #20
I have a 4510 Mahindra with a FEL. I like it except the grille/radiator design/location of the battery and windshield washer container makes it very prone to clogging the radiator when mowing in tall grass. Seeds/chaft etc get in but are not so easy to get out.
AIR COMPRESSOR 3-PHASE (A67714)
AIR COMPRESSOR...
2023 JCB 90Z-2 T4 Midi Excavator (A66734)
2023 JCB 90Z-2 T4...
CID FDM60-S 60in. Hydraulic Forestry Disk Mulcher Skid Steer Attachment (A66734)
CID FDM60-S 60in...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2018 Chevrolet Tahoe SUV (A68183)
2018 Chevrolet...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
