Loader m9540 m35 front end loader will not rise
   / m9540 m35 front end loader will not rise #1
dirt diggler
kubota m9540
So the front end loader will not lift ( goes very, VERY slowly).
Bucket will curl, but not lift. Everything else works fine.
Have switched both hydraulic filters and assume the system self-bleeds.
The controller valve switch (?) is on, am i missing something so simple here???
Thanks in advance and a great site.
   / m9540 m35 front end loader will not rise #2
Welcome to TBN:D
The most common problem when this happens is the QD's (quick disconnects), they may look seated properly but not pass fluid well. Unplug them all, wipe them down and re-connect them.
   / m9540 m35 front end loader will not rise #3
Welcome to TBN:D
Yep, I have had that happen on mine and it worked for me.
Thanks for the advice, but Murphy won't leave.
This is a newer front end loader. Was working fine daily.
I went through all 4 connections, cleaned, re-attached, and still no fix.
Do you think removing the lift controller valve(?) might do it, or is the problem in the controller box?
Still baffled, any other ideas?
   / m9540 m35 front end loader will not rise #5
Try swapping the hoses so when you try to lift you are actually curling the bucket. That should tell you if the problem is in the valves or in the FEL.
   / m9540 m35 front end loader will not rise #6
I'm having that exact problem now. Did you figure it out? I've tried cleaning all the quick connects. Haven't swapped anything out in months. All other hydro functions are fine??? Thanks. Matt
   / m9540 m35 front end loader will not rise #7
If this has a joystick controller it's possible the cable clamp isn't holding the cable firmly.
   / m9540 m35 front end loader will not rise #8
I suggest installing a hyd gage and take some readings.
Have you messed with the hoses lately.
Did you swap the curl and lift hoses.
Recheck you hose connecting at the valve for incorrect hose hookup.
   / m9540 m35 front end loader will not rise #9
I'm back in town now. I'll check for that this wknd when I get back up. It does have the joystick system with a push button on it for the grapple system. I know there are wires coming out but I didn't notice a cable. I'll check better this wknd and swap quick connects to check functions on cylinders with another line. I don't suspect thats the problem. Seems more like a control issue, but??
Thanks for the info.
   / m9540 m35 front end loader will not rise #10
Did any of you/us notice that post 1- 5 post were from 2010.
However the subject might still be relevant.
Well, I can't delete my post as the time limit has timed out.
UNUSED FUTURE CL100 40" - 10" CLAMP GRABBER (A57193)
UNUSED FUTURE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
2017 TEREX RL4 4 BULB LIGHT PLANT / GENERATOR (A52707)
2017 TEREX RL4 4...
(5) Dura Trench Drain Grates (A56469)
(5) Dura Trench...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
