jsborn
Gold Member
Does anyone have a PDF file of the parts list or the owners manual for the Kubota LA 703 including the Joystick. I know I could probably buy one but I am thrifty (cheap) and hope to find one I can download.
You might try kubotabooks.com not sure if parts manual for that tractor is listed but they have several. You can also go to tractorsmart.com and fill out a request and they will email a link to the manuals you are requesting.
Dex3361 hello! I have a L4400HST with LA703 loader purchased in Nov. 08. That a great parts manual for the loader. Do you have any info. on the tractor itself showing parts etc?
The L4400HST is a great tractor...first one I've ever owned. I'm looking forward to many projects. So's my wife, can't keep her off it! Thanks for the help, Mike.
Almost forgot--What can you tell me about Top and Tilt for the L4400.
Gloria Petty said:I purchased L4400 with LA703 loader that the dealership sold me to unload rolls of hay from trailer and move to barn etc. They even sold me the hay forks to go on front end. This tractor won't even lift the rolls off the ground with front forks or back forks. Very dissapointed in this tractor.:
You need to have the relief pressure checked on the FEL. I checked mine and found it was low. Bumped the pressure up to spec and it was good to go. You should be able to lift about 1400# depending on how it is positioned.
The 703 loader is ok but about 1400-1500 lbs is it. The LA853 Is just about as strong as my TL1000 in my opinion, if not in the lift, the curl force is about the same.
P.S. You can cheat about 5% on the pressure setting without undue strain on pump or engine, but don't go overboard.
PoorMansCat said:While I dont doubt you... I am wondering if there might be something wrong with your tractor... I have an L4400 GST with 703 loader... It routinely picks up 5x6 round bales of coastal grass.. I DID have to build a weight box for the rear end due to not loading the tires...
