Comparison GC2610 or 1526?
   / GC2610 or 1526? #11
Beaux said:
Thanks. The ground clearance difference seems large. In what scenarios does the lower ground clearance create a challenge?
Depending on how big your trees are and how big are the rocks are around you place. I have heard lots of good comments on the sub compacts and I really considered getting one. I got to test drive both and the bigger one just felt more like a tractor. I plow the snow around our neighborhood too and that is what made me decide. 24 inches of snow isn't going to move good with low ground clearance. I heard one comment about someone here on the forum breaking his transmission case on a rock. He didn't complain about it as he had a lot of hours on it. As long as you watch what you run over and keep the ground clear in front of you, you would probably be fine. One thing to keep in mind is if you run over little saplings. The are going to fall the direction you are going. The minute you try to back up over your path those little stubs will try to poke up into your tractor and can damage something. Always try to make sure the path is clear or find a clearing and turn around so you can clear the opposite direction with your FEL. In other words make sure you know what is underneath you. No matter the size of the tractor the hazards will alway be there
   / GC2610 or 1526? #12
One other thing. At least you are considering a Massey Ferguson. I'm pretty partial to them and I think a lot of the guys in this thread is too. I think very highly of their product and have been around several of them in my lifetime. I am by no means an expert advisor but the tractors I have been around has been great. No matter what you get there will be troubles of some kind sometime. That's just Murphy's law.
   / GC2610 or 1526?
Very helpful perspective. Thank you.
   / GC2610 or 1526? #14
Also ground clearance 11" vs 6.7". 91 ci engine vs 68 ci engine 3 speed hydro vs two speed hydro. Pro about the 2610 is that you will have a backhoe. Very small but they are handy for digging out saplings and smaller stuff.
That comment will get a whole bunch of GC owners in an uproar. GC's are capabable of doing much more than just 'saplings and smaller stuff'.
Edit: here is sapling that a GC2410 can remove: http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/132330-stumpin-w-2410-a.html
   / GC2610 or 1526? #15
Haha. Gotta stir it up some. I run heavy equipment for a living and our excavator cat 345 will swallow up a 2410 in one bite. When I get off of it and go to a small hoe it makes you fill like you are on a tonka toy. No insults intended. Anything is better than a pick and shovel any day :). I wish I had a small hoe at times here at the house. I have no doubt they serve their purpose. Besides its a Massey :)
   / GC2610 or 1526?
Holy cow! That's a stump! Looks like this tractor will work just fine. Next question: what constitutes "good deal"? I was offered on for (his off the top of his head price) $16500. I was then informed I could get a $2000 discount from that figure if I paid cash.
Thoughts?
Thanks again.
   / GC2610 or 1526? #17
Hi,
I think the value for the Massey exceeds the other color paints so to speak. The dealer offered me no better deal on the 15 series vs the GC series but I think it is a good time to buy with the promos they have going on. I think your choice will be a personal one, all you can do is make an informed one. The dealer did convince me to load the tires for my use. Dragging a lot of lumber out of my woods and a couple of driveways to plow. I am also think the rear snow blower due to price and the ability to keep the FEL on for clean up and moving a piles of snow if needed. The thought of hooking up a blower or FEL when its 10 degrees does sound like much fun.
COGINCHAUG= Long swamp
   / GC2610 or 1526? #18
How much difference in physical size and maneuverability between the 1526 and 1529? I'd also like to see a 1526 and a GC side by side.
   / GC2610 or 1526? #19
Hi COGINCHAUG
I think the area that you are in a nice Massey 1533 cab with heat to blow snow would be the way to go. Also plenty of power to pull trees and anything else gets in the way.
   / GC2610 or 1526? #20
My 1526 was parked right next to a 1529 when I bought it. I could have gotten it for about $700 more and both was hydrostatic drive. There is a little bit of difference in height and ground clearance. I had all that stuff on a sheet for comparison somewhere on the computer. The loader has quite a bit better lift capacity. I don't think it would get around any worse than the 1526. Here is a picture of the 1526 next to a gc2610
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
1983 Case 580D (A47477)
1983 Case 580D...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
