what to look for in a used stick welder
   / what to look for in a used stick welder
here is a picture of the plug:
   / what to look for in a used stick welder #3
Aside from the splice job on the power cord, that looks like a pretty well preserved specimen. Check to make sure that the fan runs smoothly, without any squeaks or clattering. The amperage core should move throughout its travel without binding (if it's a little stiff it probably needs cleaning and a spot of lube). The plug ins for the leads should fit snugly and not fall out just by moving the cables. And of course if you do get it autopsy that splice.
Check out the leads for big cracks in the insulating jackets and overall condition of the ground clamp and stinger.
I believe that Millers have a pretty high open circuit voltage so striking and maintaining an arc is a lot easier than say a Lincoln tombstone which has a 24v ocv. Should make a pretty nice welder for you, it's at the top of the price range for stick machines as the market is flooded with them now.
   / what to look for in a used stick welder #5
Those are good general purpose welders. Crank the adjustment up all the way and down all the way. If it feels raspy in places it has likely been overheated. I have used various buzz box welders for 30 years and they have served me well. :thumbsup:
   / what to look for in a used stick welder #7
One thing I always look for in a used welder, is how smooth the arc is at really low amps. Any machine will feel smooth running 1/8 inch 7018 at 190-amps. But the question is, how smooth is the arc when running 3/32 inch 7018 at 55-amps?
   / what to look for in a used stick welder #8
1/8" 7018 at 190 amps? That sounds pretty high. I tried some earlier at 150 and it was undercutting a bit. Maybe it depends a little on the brand...?
   / what to look for in a used stick welder #9
The point is, any machine looks good running balls to the wall. The trick is how stable they are at very low amps.
   / what to look for in a used stick welder #10
I got that very same welder, a 15 year old thunderbolt.
I usually run Lincoln 1/8" 6013 sticks at about 80-85 amps, AC.
CATERPILLAR HM418C 72" HYD MULCHING HEAD (A52705)
CATERPILLAR HM418C...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
golf cart (A55758)
golf cart (A55758)
2000 POLARIS MAGNUM 325 4-WHEELER (A51406)
2000 POLARIS...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
