tractorski
I have a MF 1652 with a shuttle shift, will it work?
pulls down the hitch pulls up probably doubling the machine's traction.
The 1652 is a large frame compact right? 3 bottoms unless its 12" bottoms is too much for here. I pull a 2 bottom 16" Overum which is an easy pulling euro bottom and it is about right for my 50 hp Kubota cut that weighs about the same as yours. I keep the loader on, it in 4wd and the rears are loaded to pull it.
I was plowing with a Kneverland 3x16 last summer with a 120 hp 4wd Ford/NH 8630 with a full rack of front weight and if you took the 4wd off she would stop dead. Not ideal ground I was plowing though. I bought the plow and will be running it on my 100 hp MF but I won't be able to go as fast.
