Welding Table Ideas
/ Welding Table Ideas #1
david12171951
I need every ones help again, I want to build a small welding table. I have a piece of 3/8 plate that is 30" x 36" , Some 1.5 " x 2" x .25" angle. Know i will need something for legs. This will not be for any heavy fabrication just shop type use. Also have some deck grating I would like to mount on and off of one end. Have some slab and some rough ground ( hard sand and grass) I would like to move table across some. Ideas of any type wanted for table and fixtures. No front end loader so table needs to skid or be on wide wheels if possible. Health not very good any more this is why it is this size. Thanks, Dave P.S. Been using a manhole cover with legs for years now, makes a solid table but very small and very heavy!
/ Welding Table Ideas #2
Hi Dave,
I built myself a welding table about the size you are talking about. I used 1 1/2" x 1 1/2" angle for the frame. For the legs I used 1 1/2" sq steel tubing. I put steel wheels from HF on two of the legs and just let the other two legs sit on the ground. I built the frame larger than my welding table. I made the frame large enough so that my chop saw will sit in between the rails. I can also remove the chop saw and put a grate in that space for cutting with the torch. Below the chop saw / grate is a large open top metal box made out of 16" sheet metal. It catches all the slag from torching and chop saw and also small scrap pieces of metal. I would also suggest welding under the table two receiver hitch tubes. This way you can put a vise or other accessories on 2x2x.25" tubing and slide into the receiver tube, when needed. Other ideas, use some U bolts on the sides to hold your small sledge hammer, torch, mig. If you can find a metal drawer that would really be nice to have at the table also. This way you can keep your safety glasses, gloves, marking utensils etc all handy. Another idea would be to have a piece of U channel on one side to hang your grinder / cut off wheel. How about adding an outlet box with extension cord so you have an electrical outlet handy.
Miller makes a welding table, they have slots cut in the top for mounting c clamps. I don't have that, but maybe in the next one I build...
/ Welding Table Ideas #3
To quote someone else on here " without pictures it didn't happen"
QUOTE=F250DSLPWR;2763132]Hi Dave,
Miller makes a welding table, they have slots cut in the top for mounting c clamps. I don't have that, but maybe in the next one I build...[/QUOTE]
/ Welding Table Ideas #4
I have a little welding table that is about a 36" diameter circle. I love the size. The one modification I plan to make someday is to shorten one leg and weld on a very large nut. I'll put a bolt in the nut and that will be my adjustment to make up for my old uneven shop floor.
/ Welding Table Ideas #5
I think I would build a table about 5' long with the plate top and the grating on one end about 30"x24" inclusive. This would make the table about 30x60 overall and is a very convenient size, easy enough to reach across yet big enough to do some real work. The sheetmetal pan below the grating is a good idea also, my last welding table I built years ago didn't have the pan and it makes a mess of the floor.
Depending on what resources you have I would recommend that the horizontal frame pieces be the more ridgid steel and the legs can be the smaller sizes. Reason being the legs are in compression for the most part while the horizontal rails need to be very ridgid without bending.
/ Welding Table Ideas #6
I worked at a truck dealership and got two side plates from cement mixers, they are 5 ft x 2.5 ft 5/8 thick. There is a hole in the middle a little off set. I welded one with the rounded flange up and one down. I used pipe for legs and channel Iron on the bottom with a piece of 2x4 across it slides OK and is quieter, I have angle iron between the legs for a shelf but want some grating. I have my "C" clamps hanging on it now.
You can go to a lot of used steel yards or used equipment yards and find all kinds of stuff. I look threw lots of them when I have the chance, sometimes I see something, that gives me an idea to make something.
/ Welding Table Ideas #7
I have a welding table that my Dad built, years ago. It's a cast iron table saw top. Mine has straight legs made of 3" channel, but your angle iron would work. Even better, find one at the scrap yard (or a garage sale) that comes with wheels.
/ Welding Table Ideas #8
My table is not very large, 24 X 36 by 5/16 plate that was cut perfectly square in a sheer.
I welded angle stock about 2" back from the edges and made the legs wit angle stock with a shelf about 3" above floor level that my welder lives on.
Another shelf is about 1" above the welder.
I like the 2" frame setback as I can clamp work at perfect 90 deg angle at corners to do precise weld joint.
The shelf arrangements stores all my equipment, rods clamps etc. with the all using minimum floor space.
I build a fair number of fireplace doors on that table.
Also made my tractor cab on it as well a lots of misc jigs doodads etc.
Works fine for me.
Never did add wheels, simply wobble it around when I need to.
Oh, did add hooks to hang the cables off to one side.
/ Welding Table Ideas #9
I got this table off Craigslist, not exactly what I would have built but the price was right... It has served me well for many years.
Larry
/ Welding Table Ideas #10
Weld a length of angle iron to one edge ( " V " up ) to hold round material without clamping. Later you'll be surprised how much you use it for lay out work. Weld it to the side you'll will be working from most often.
/ Welding Table Ideas #11
Larry,
What do you think of the diamond plate surface? I have some 1/4" 3'x5' diamond plate here that I will probably make a welding table out of but I was planning on turning it up side down so that I have a smooth surface. I assume that would be better, but did you find an advantage to the surface you have?
Ken
/ Welding Table Ideas #12
[/QUOTE]
I guess I need to clean the junk off of it and take a picture or two and post it! :D
/ Welding Table Ideas #13
I think it depends on the weight of the material you anticipate welding.
3/8 material would be too heavy and overkill for me. My table is just a 1/8 steel sheet welded to a 1" tube frame sitting on legs I made from bedframe rails. I won't be fabricating a box scraper on it, but it's fine for what I do.
/ Welding Table Ideas #14
hello all,
My son and I built a welding table few months ago out of a 3x3x1"1/2 plate steel with 3"x 36" pipe legs 1/4" wall.
Its not real big but you can put anything you want on it and bet the DOG out of what ever is on it.
Weights about 250lbs ??? not sure but it's heavy.
The only reason I used the 1"1/2 plate was it was free and guy that taught me how to weld had one that thick.
Hope this Helps
BE SAFE Carl
/ Welding Table Ideas #15
I was thinking about just picking up an old (hopefully broken) table saw for a welding table, but an old (nothing powered) medical examining table made itself available. I figure I might need to beef up the work surface some, but I figured I'd see what breaks first.
/ Welding Table Ideas #16
Sounds like a good find :thumbsup:You could just lay a smaller piece of 3/8" over part of that table for your main work area.
It's surprising what can work vs. the ideal. Craig's list has had a welding table listed for a while that is 4'x8' with a 4" thick top! (WELDING TABLE) OTOH, I've been using an old metal clad door on a pair of folding plastic saw horses:laughing: I have a section of 6" I-beam that I do most of my welding and pounding on and it's been working out pretty well until I'm ready to build an actual table.
/ Welding Table Ideas #17
For the longest time I used a top off of a metal desk. I'd flip the top upside down on my metal table saw. The table saw kept the desktop flat and level, and the desktop kept the table saw from getting pits or spatter on it.
Now I have my little 3' diameter circle table that meets my needs just fine.
/ Welding Table Ideas #18
I've seen some nice ones made of spaced flat bar on most of the top. Lets you tuck c-clamps in. There is usually a solid 2 ft wide piece on the end by the vice to weld small stuff.
/ Welding Table Ideas #19
Speaking of that kind of design with slot across the top, a guy over on the welding forum is making one out of 6 or 8 inch H beams (like an I beam but the flanges are flat).
Ken
/ Welding Table Ideas #20
Here's mine. Got the grate from the old high school welding shop for 20 bucks. Had some 3" heavy wall tube laying around and added a 1/2 bottom shelf with expanded, overhead light, and 2 pcs of 5" angle iron with the V open for clamping and welding round parts. Added some 4" castors to move it around easier. Also added square tube to hold either a small vise or my hand shear reciever hitch style. I built this the same height as my main workbench so it does double duty holding long steel or wood projects.
Nice thing about the expanded and the grate is all slag and junk falls thru to the floor.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
6 Row Unverferth 430 Ripper Bedder (A64119)
6 Row Unverferth...
(2) STACKS OF APPROX (50) EACH OF 24" X 112" (A64280)
(2) STACKS OF...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
