Buying Advice New Holland, Kubota, Mccormick, Case, or Mahindra
   / New Holland, Kubota, Mccormick, Case, or Mahindra #1
chickenman22
Member
Chesterfield, VA
ford 7600, 3930,3550,3000,2000 kubota M5, Mccormick x10.50
Hey guys...need a little help from the owners or dealers of these tractors. I need to get a new 4wd tractor for the chicken houses and for hay. I'm looking at getting a 40 to 50 hp but cant seem to make up my mind. I have little knowledge of these newer tractor with the hst, but I'm kinda liking it. Height is my biggest issue considering I have limited space in the houses. I can't stand the ROPS that they put on everything now. Does anyone have any words of wisdom on the durability of these tractors. So far I'm leaning toward the Mccormick but cant find much info...PLEASE HELP!!!
BTW, MCCormick is the only one i found with the full folding ROPS that break at the fender opposed to 2 feet up. the model of the Mccormick was the x10.50h. And never really been a fan of JD due to them putting an aluminum axle housing in. Prolly still gonna check them out just to be on the safe side.
   / New Holland, Kubota, Mccormick, Case, or Mahindra #3
if your wanting an HST tractor then id look at the MX5100 HST 4x4.it should fitt your needs nicely.
I'm worried about the kubota not having very good lift capacity and the height of the tractor is too tall due to the rops. The ceiling height in the houses is pretty low bc of the water lines
   / New Holland, Kubota, Mccormick, Case, or Mahindra #5
All of the larger Kioti's also break the ROPS at the fender line.. Kioti=McCormick=Bobcat=Landini.. all made by Daedong
I hope they are good, I am trading in my Kubota for a Kioti DK35se next week if they can ever get it prepped (supposed to have been today, but some sort or trucking issue ,truck late)
In 40 horse the DK40se Hydro is a good value.. I priced one at $22495. Others have gotten 21500 or so. 40 horse 2700 lbs of lift on the FEL, hydrostat with 1 rear remote, Luxury features.
James K0UA
   / New Holland, Kubota, Mccormick, Case, or Mahindra #6
My DK40(mccormick) sits pretty tall on Ags, but probably I could be comfortable going under 6'6" with the ROPS down. Its about 5' to the top of the seat, but it is adjustable up or down. The turf tire option lowers it about 2" as well.
   / New Holland, Kubota, Mccormick, Case, or Mahindra #7
I was kinda wondering why you need such a large tractor for chicken house clean out, or do you have other used in mind for it too?
James K0UA
I also need it for hay and just multi purpose....can never have too much power.lol.
   / New Holland, Kubota, Mccormick, Case, or Mahindra #9
If I was buying for a hay farm I'd get a dedicated ag tractor and not a CUT.
Most of the major manufactures build low profile models in the 60-80HP range for poultry/orchard operations. They'll move right into a hay field......
Do u know the model and brand of any of the low profiles?
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
1328 (A58374)
1328 (A58374)
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
