Thanks for all your chatter!
/ Thanks for all your chatter! #1
lmwashere
Martin, Ga
LS R3039
This has probably been the most helpful site that I have found in my tractor search. I have been reading pretty much everything I could find, studying up to make a tractor purchase. I finally pulled the trigger on an LS R3039 last week. It should be here sometime next week. I can't wait to play with it!
I decided on LS because of the value/price ratio. A major factor in that was the warranty, as well as the awesome dealers that I have spoken to. Don't get me wrong, there is a Kubota/NH dealership close to the house and he was nice too. There is also a JD dealership within about 4 miles. JD dealers are proud of their equipment though. I don't have any complaints about their service, but neither one went above and beyond like the LS dealers did.
If you are in the North Ga/SC area, I had a really good experiences dealing with Willard's in Walhalla and Atlas Sales in Cleveland. Ultimately my decision was made according to who had the best price. I would happily deal with either one again though and the price difference was only about $400 after figuring in the loader and all of the extra equipment.
(6ft finishing mower, 5 ft tiller with slip clutch, 14 in bottom plow, 1 row cultivator)
I decided on the r3039 because it was small enough for me to pull in a pinch with my current vehicle, but still has the Mitsubishi 4 cyl. The R4041 would have been nice, but then I would have had to make arrangements to borrow a larger truck if I needed it to be somewhere else.
The G3033 would have been big enough to handle about any task I had for it, and there is something to be said for it's utilitarian design. Nothing to break as the saying goes.
In the end I decided that I liked the extra features of the R series over the G series. It may not be the perfect tractor for everyone, but for me I think it is. And as my father used to say 'that's why they make so many flavors'
From reading this forum I learned that chain hooks and filled tires are a good thing. So... I had those added. Well, sort of. When I asked the dealer about the hooks, he said something to the effect of:
"I can weld those on if you like, but let me show you what I think works better"
He then showed me these loops. As it turns out I was planning on using some 10K lb straps to do my moving anyway. I think that these loops will work much better for that, and they have much more surface area to weld to the bucket. I will post some pictures when I get it, so you can see what I am talking about.
In any case, thank you all for all of your questions, responses and debate. They have been terribly helpful in my decision making process!
/ Thanks for all your chatter! #2
Welcome to TBN!!!
I'll be very interest in seeing the pictures of the loops you mentioned...
/ Thanks for all your chatter! #4
Welcome LS yes.
/ Thanks for all your chatter! #5
Nice first post! Welcome to TBN. Of course you know we expect pictures, right?
PH
/ Thanks for all your chatter! #6
I'm also interested in this loop thingy:) I also just received an LS 3010 tractor. I did make a set of rear tire chains and have a snowblower. Still need to get pictures. The chains I built{rebuilt} are just a simple set that I reworked to fit. I do believe I'll add an H patern to them this summer. So far I am very pleased with the machine very user friendly. The only thing I'm planning on changing is the 4wheel drive lever it's hard to reach especially for someone with a very bad back.
/ Thanks for all your chatter! #7
If I have the right idea in mind on the loops, it sounds like something that could be added and still have hooks too. I want to see it too.
The loops look kinda like this:
I got 2 sizes, 16000 lb on the front of the bucket and 40000 lb on the back where the metal is heavier.
Either one should be more than strong enough, but I can fit the hooks on the ends of my straps through the larger ones.
The picture of the bucket will help to explain.
/ Thanks for all your chatter! #9
Congrats, that's the same tractor that I have. Mine was delivered just before Christmas and has about 14 hours on it now.
Thanks, I am very anxious for it to arrive. I have not even seen it. I drove one of course, but not mine.
/ Thanks for all your chatter! #11
Congrats on your tractor, I hope it serves you well.
The loops are no stronger than the bolts that hold them but as you said the dealer will weld them. The loops look just like what I have mounted
on my hay trailer to tie the bales down. They are stout but I can't think they
are rated at what you said, but I may be wrong.
If the loops work better for you then that's great but
they are not nearly as strong weld hooks.
/ Thanks for all your chatter! #12
The loops are no stronger than the bolts that hold them on unless your dealer is going to weld them in place. The loops look just like what I have mounted
Based upon the picture, I'd have to agree...
Can't choke a chain with 'em either.
As I said, kinda like that. The weight ratings are actual, so the size is not accurate on this pic. it is just the first similar pic i found on the internet. The metal that makes up the ring on the large ones is roughly 3/4 to 1 inch thick. I didn't really need that much strength, but the opening of the loop was right to get the hook on my straps through.
No, you are right, you can't choke a chain with them. That crossed my mind, but I would have to buy a chain, I have the HD straps. They will hook on and loop through. I figured if I ever decide to use a chain, I could pass the chain with a hook through the loop. It would have to be a pretty big hook to go directly on the loop. Hooks on the bucket would force the straps sideways, and would have to be pretty big to fit the hooks that are sewn onto the straps. These loops may not be as good for chain, but I think they are more versatile.
As for stronger than hooks, I dunno really. Maybe they are, maybe they aren't. It seems logical to me that more surface to weld to would make a stronger joint. You could be right though. I guess it depends on the size and strength of the hook, and the quality of the weld.
/ Thanks for all your chatter! #14
Congradulations! Exciting times.
If you need to choke your chain:D
/ Thanks for all your chatter! #15
Congrats on the LS tractor purchase!
I have a pair of those weld on rings for my bucket(havent welded them on yet)...I like the idea of using straps and d-shackles..some dont but that is my preference..I hate chain other than using it to skid firewood out of the woods I dont have a use for it.
OK, so I thought he said, 16000 and 40000... perhaps I was smoking crack. He said that he thinks they are 11000 and 20000. No matter, they aught to be strong enough either way. Here they are:
Didn't even take the manual off of the ROPS first.....
This thing does a jam up job clearing my brush. I need to work on my loader skills though. I'm a little rough around the edges.
/ Thanks for all your chatter! #17
Nice looking tractor!!
We were all a little rough around the edges when first using a loader...you'll get better.
/ Thanks for all your chatter! #18
Just FYI..., one "school of thought" on bucket hooks and rings is that they should be placed inline with (or inside of) the loader arms to prevent tweaking of the loader. My dealer welded a couple of grab hooks on the outside edges of my bucket like yours, so I added some angle iron and stuff between them. But, now I usually leave the grapple on.
Just FYI..., one "school of thought" on bucket hooks and rings is that they should be place inline (or inside of) the loader arms to prevent tweaking of the loader. My dealer welded a couple of grab hooks on the outside edges of my bucket like yours, so I added some angle iron and stuff between them. But, now I usually leave the grapple on.
This is good to know. I had not heard that. I will be sure to only use the inner ones for heavy lifting. The outer ones should be fine for light duty right?
And thanks Roy. I only got to play with it for an hour before my wife made me come in for dinner. It's OK though, the ground really needs to dry out a bit anyway. I don't want tire marks everywhere.
/ Thanks for all your chatter! #20
I have two hooks outboard of the loader arms and one at the center.
As long as one uses the two outboard hooks simultaneously (spread the load), there shouldn't be any problem with tweaking the loader frame.
The center hook is only used for light loads (pulling smaller trees and such).
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
Unverferth Perfecta 12 (A64126)
Unverferth...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
