What you need to know about miss Utility
   / What you need to know about miss Utility #1
kdm0811
Lynchburg, Virginia
BX24 and RTV500
I think that anyone with a back hoe, FEL, (or shovel), should know about the experience that I had with my telephone company last year when I installed a board fence around my 4 acre horse pasture. I started by calling Miss Utility to request the marking of utility lines that my fence might cross. I had marked the proposed fence line to assist the utility locator service. The locator service determined that a telephone line crossed under the proposed fence in 2 spots. They marked the buried telephone line with orange spray paint. I was told not to excavate within 24" of the lines. I was also told that my "ticket" would expire in 15 days.
The fence is a (very horse friendly) conventional 3 board design with wood post fence on 6 foot centers.
Soooo, I started boring 330 post holes for the fence. In doing so, I found EVERY rock, stone, and boulder that I own! By the time that I arrived at the second fence crossing site, I had been drilling for 3 weeks, and broken about 20 shear bolts on the auger. I targeted one of the two fence post holes at 30" from the center of the orange spray paint that was still clearly visible in the ground.
I did not know that I had cut the cable to my neighborhood until I saw the telephone truck roll up. Looking down the hole, there it was. The severed cable. However, I was in the center of my hole (30" from the orange mark)!
I was told that I was at fault because I was excavating with an expired work ticket. My assertion that the hole was located according to the erroneous utility locator's mark was dismissed as "irrelevant". I was told that I should have had the ticket renewed (even thought the orange paint was perfectly clear). I was also told that if I had drilled the same hole a week earlier (damaging the cable) it would not have been my fault.
A week later I received a letter from the phone company requesting the contact information for my homeowner's insurance agent. I responded with a letter explaining my position (everything above), and that they would be better off to determine why the marks (of a cable 14" deep) were 30" off.
2 weeks later, I got a more threatening letter indicating that I owed them $873 in damages. I responded with another letter, and included a copy of the first.
Then the phone calls started. I maintained that the time of the damage was completely independent of the cause of the damage. The calls were very threatening and implied that they had a room full of lawyers ready to take me to task if I were to request a 3rd party review of the situation. None the less, I was not at fault, and I was not going to pay.
It took me 6 months to reach a person of authority, accountability, and intelligence within the phone company. But I finally did, and my case was change to "DO NOT BILL".
In summary, if your project goes past the "ticket date", call the SOBS out to mark it again. And if there is damage that is their fault, FIGHT IT. The system is strategically set up to cause you to fail and give up. But I am proof that you can win!
One other thing, take lots of pictures of the marks, utilities, and excavation with yardsticks showing the pertinent locations of each.
   / What you need to know about miss Utility #2
OMG what a story and they did all this for a louse 873 dollars..Unreal..Thanks for sharing..
   / What you need to know about miss Utility #3
Had it been relocated it may have been marked correctly.
   / What you need to know about miss Utility #4
I called for buried utility locate. The phone company came out but not the cable company. I checked my ticket and cable company marked it as not in the ground or something that said they did not need to mark. I called the utility locate service and told them the cable company was wrong. They sent someone out to mark the 1/4 mile of buried cable that my fence was going to miss but I wanted to be sure. I was right of course about the cable being in my work zone.
   / What you need to know about miss Utility #5
Wow that is crazy. Glad to hear you finally got it worked out.
   / What you need to know about miss Utility #6
...I was also told that my "ticket" would expire in 15 days...I had been drilling for 3 weeks...I was told that I was at fault because I was excavating with an expired work ticket...
Everyone always seems to think that "the man" is out to get them. In my neck of the woods, calling for utility locates is law. Since it is a legal matter that determines liability of damage, parameters must be clearly defined. A locate ticket cannot last forever and must have a clearly defined length of effectiveness as yours did and as aknowledged by you in your post. The terms of the "contract" were not held up on your end. The entire incident could have easily been avoided with a simple phone call on your part.
All of that being said, I'm glad you were able to reach a voice of reason and settle the issue to your satisfaction, even if, IMO, you were at fault for not renewing the ticket. I've been in the utility construction industry for 17 years and this is just one of the issues that you have to learn to abide by... if you damage a utility, and don't have a valid ticket, you're responsible for the damages. Whenever we have to excavate near a utility mark, we hand dig to expose the utility and visually verify it's location before sinking any type of equipment into the ground.
It turned out well for you in the long run, but I would still chaulk it up as a lesson learned for the next time.
   / What you need to know about miss Utility #7
Glad you were able to get that situation resolved in your favor without having to lawyer up. However, you are so right that the "system" is setup to cause you to get so frustrated that you eventually give in to their demands and threats. That seems to be true with every utility in this country! What's so ironic about that is the people that work at those utilities have relatives, friends, neighbors that are the ones that the utility is trying to walk all over. I guess those employees look at it as just doing their job lol.
   / What you need to know about miss Utility #8
Another option from the beginning would have been to measure off your holes for fence posts and dug the ones near the underground lines first...
   / What you need to know about miss Utility #9
I find that alot of the local cable and phone wires aren't even buried (house drops). I remember driving my F550 service truck over a cable one day and got a call from the cable company that I owed them for the repairs. I told them that the line on top of the ground with only a few pine needles over it was improperly installed. They threatened but I ignored them, I knew they didn't have a leg to stand on.
   / What you need to know about miss Utility #10
Last year I was lucky. I was trying to save myself some tough hand digging in our hard clay and got too close. The mark was off from the telephone cable but they warned me and I cut it. Repairman said he would turn it in as some incidental thing and I didn't get charged. Sometimes you get the right guy.
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
