Egon
Epic Contributor
Is the op going to be welding underwater???
Take a look at this link
Underwater Welding Dangers
Second note under "Underwater Welding Dangers"
There is more information about this. People still wonder why or how the tank exploded???
Is the op going to be welding underwater???![]()
Yep, if that were the case, every time you boiled your potatoes on a gas range, the kitchen would explode. It takes electricity to separate the water molecules into hydrogen and oxygen. I fiddled with making a hydrogen booster for the car but figured out that it would be entirely too complicated to regulate the ratios.
Ian
I dont think some peope can read or there is way to much information provided and it is confusing everybody. The suggestion to pay someone $80 to weld the tank when I have already posted I can buy a new one for $46 was ridiculous. No Offense, but did you read the entire thread or just miss the part about the cost of a new tank. I also never said I was going to weld the tank under water, where did this come from. In fact I said the tank would be full of water except for about an inch below the top of the filler neck that protrudes several inches above the tank. There will be no welding in water and any moisture present in the weld would be whatever moisture is contained already in the welding rod. Maybe I need to take some pic of the tank to better show what I am wanting to do. Basicly I just need to weld a short nipple to the top end of the filler neck to accept a vented gas cap. Water level would be just below the nipple and tank would be completely full. Any hydrogen created should easily dissipate to the atmosphere since there really isnt any place for it to accumilate or create a pocket. Its a 2in nipplel about 2 inches long, with one end completely open, just how much gas or hydrogen fumes can accumilate in that amount of space.
I dont consider myself an expert and think I made evident my desire to do this as safely as possible or not at all. I also have been around a long time and realize the danger presented with welding on a gas tank. The fact that I have already looked at other options, buying a new tank or building a new tank, should suggest that I am not at all comfortable welding on that tank. Still I think flushing this particular tank and then filling with water should eliminate any possible flash potential. I say this because the tank design is a square, welded steel that can be completely filled with water to eliminate all void or possible air pockets that could hold the explosive vapors. Filler neck is on the top of the tank and not on the side. Now, if this tank was one of those stamped steel tanks and the hole was in the bottom, or I could not completely fill the tank with water, I probably wouldnt even consider sticking a torch to it
