Widening a Snow blower (not wings)
   / Widening a Snow blower (not wings) #1
ericher69
Ontario Canada
2008 Kubota b2920
Here's my problem
Front blower 51"
Rear blade 60"
4.5" overlap/spoil on back per side
Was thinking about wings but...
Has anybody ever widened a blower? I was thinking of just buying the front shafts+augers and widening the working width to 63"!
I called the dealer for a 63" blower and even with trade in of 51" it's still $2500!!
This is for a kubota b2920
   / Widening a Snow blower (not wings) #2
Unless you need that 63" rear width it would be simpler and less costly to narrow the rear blade. Possibly retain the blade ends and make them into fold back or detachable wings so you put them back on for summer use.
Reason I do not want to go this route is that I do residential snow removal and the tractor could easily handle the extra width!
Also it would reduce my time/drive increasing profit/hour
Thanks for the reply
   / Widening a Snow blower (not wings) #4
Here's my problem
Front blower 51"
Rear blade 60"
It will cost you every bit of that to modify yours.......if it can be done.
My advice is to make suitable 'wings', or buy the bigger blower.
   / Widening a Snow blower (not wings) #5
Have you checked material costs for new auger(s) and steel? Do you have the facility to do it yourself? And also consider downtime, what if it snows while blower is in pieces? Just things to consider versus the $2500 trade.
How about trying advertise your 51" for a couple weeks, see if you can sell out right then buy the 63", dealer trade allowance is considering his resale profit margin.
   / Widening a Snow blower (not wings) #6
I'd get a bigger blower. But then again I love to spend other peoples money.
Or a smaller blade, or I'd just angle the blade.
Wedge
Material costs about $500
Looking at the blower it is all flat pieces of 3/16 mild steel plate
I've got the equipment and know how to do
I would finish the winter as is and modify in the spring or summer
   / Widening a Snow blower (not wings) #8
When I had my Kubota L39, my Mackee M520 snowblower measured 72" which was perfect for that tractor's width....when I upsized to my current M59, I found the wheels tracked into the banks when turning....I added wings on the blower extending the width to 81", 41/2" on either side.
It's worked perfectly for my needs and a lot cheaper than replacing total equipment. :thumbsup:
   / Widening a Snow blower (not wings) #9
Where did you get the yellow sticks? Nice job.
   / Widening a Snow blower (not wings) #10
Here's my problem
Front blower 51"
Rear blade 60"
If you do go that route, post pics please? :)
2012 International Prostar (A56435)
2012 International...
Kubota BX25D (A53317)
Reading Classic I I (A57880)
Reading Classic I...
2012 Ford F250 (A55973)
2012 Ford F250...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
