What strange things have you moved with your loader..pics
   / What strange things have you moved with your loader..pics #221
I didn't move it too far but used the FEL to lift the light standard off its base, installed a new HPS fixture and stood it back up.
   / What strange things have you moved with your loader..pics #222
couple things i have moved. And always looking for the next thing.
   / What strange things have you moved with your loader..pics #223
Not a very unusual use of FEL, but I recently used mine to move an old deer stand to a new site and then put my new box stand up. I had the pipe base in place back in May. Moved the new box stand from my shop to the hunting lease, which is 60 miles away. Used tractor to offload from my gooseneck and then raised it into position on pipe base. Pucker factor was very high during this lift. Had to get the base of the stand just over 7'-6" high before inching forward to place the box on the pipe frame. You can just make out the cutouts for my forks. Third picture shows the old stand in route. You can just see the new stand way in the back ground.
[/ATTACH]Deer stand move.jpg
   / What strange things have you moved with your loader..pics #224
i have a buddy that moves his blinds that way!
   / What strange things have you moved with your loader..pics #225
Installed my 250 gallon tank. Now my heating system is owned not rented. Not that I was going to rent my tank but that is a story for a later time.
   / What strange things have you moved with your loader..pics #226
When I was building my shop, 30x40x12, I fabricated a boom pole that I attached to the FEL and used it to raise the roof trusses for the shop. Later I wanted to put doors on my hangar so I welded up a 42' x 6' truss. I used the boom pole on FEL with a bush hog attached in back to raise that truss up 12' to rest on the supporting pipes. That, I would say, is the most precarious lift that I have done with my FEL. Wish I had some pictures of that.
   / What strange things have you moved with your loader..pics #227
This was me testing out my fel to 3pt attachment using my 3pt forks. I moved the old decrepit mower to the back of the garage for the "scrap for parts or money" area.
   / What strange things have you moved with your loader..pics #228
Moved this old wood stove to get melted down. I don't know how much it weighed but it was heavy!
   / What strange things have you moved with your loader..pics #229
I was rather enjoying this thread, I'll add an experimental aircraft engine. :)
   / What strange things have you moved with your loader..pics #230
Proof, Man, we gotta have proof! That's just a plywood box!
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
flooring (A55758)
flooring (A55758)
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
Sterling 9500 (A56436)
