Citizen Band radios?
/ Citizen Band radios? #21
I wish I still had the Corona Mark II. It met its end when a '68 Caprice failed to yield right of way and cut in front of me...totaled it. I did learn from the accident I should wear a seat belt, good thing I have a hard head.
/ Citizen Band radios? #22
I still have my old Teaberry Tele-T 23 in the basement. It works fine and looked cool in my car back in the 70's! :thumbsup:
/ Citizen Band radios? #23
Wow haven't seen one of those in a while! That thing was made to look like an IMTS mobile phone from the late 60's or early 70's. more or less. I wonder what it would bring on e-bay..
James K0UA
What's the farthest skip anyone has done? I hear NorCal, New York, and Mexico pretty regular. I got out to NorCal once, but he could barely make out Mississippi. I'm two hours north of New Orleans.
/ Citizen Band radios? #25
James K0UA
Not gonna sell it! :laughing:
/ Citizen Band radios? #26
I used to talk to a guy in Louisiana once in a while from South Bend, Indiana. Damp nights with fog and low clouds always brought out the long distance.
/ Citizen Band radios? #27
My Uncle and Grandfather were in to it years back. In the 60's, they both got portables for their cars. They were about a foot wide, foot deep, and 8" tall. Tubes...
My Grandfather had a Pace base station for my Grandmother. Again, 23 channel, tubes. He hot-rodded it a bit.
Interestingly, that old 1960's base station is still in use at the fire station up outside of Portland, Or. Lots of guys still have CB's on the farm tractors; if there is a volunteer FF response, easiest way to reach them is with that radio.
My uncle still has the other two mobile radios.
Oh this thread brings back memories. I too had the CB - 23 channel back in the late 70's. I remember sending off for my FCC License - thought I was a cool teen.
/ Citizen Band radios? #28
I have a cb in the 4WD truck, handy when on the logging roads, as the log trucks and dump trucks broadcast direction and mile marker so you don't run into them or vise/versa.
I also am a ham, and have a 2 meter in the truck and car. A lot local short haul truckers are hams and use the local 2 meter repeators to keep them awake on their night time runs.
If you buy an "export radio" and start using parts of the 10 meter band, people like me will be reporting you to the FCC. Fines start at 10,000 bucks, and it is hard to get out of the fine.
/ Citizen Band radios? #30
So a 2 meter is OK to run without a license or it;s low enough range so you're not such a nuisance?
No, you need at a mininim a technician class Amateur Radio license to get on 2 meters. And you will get caught in a heartbeat on 2 meters (144 to 148 Mhz) without one. Power level is up to you. From milliwats to 1500 Watts maximum. Most mobiles run anywhere from 25 to 75 watts with 50 being very popular. Most hand helds from 1 to 5 watts. Most home stations are still at about the 50 watt levels, tho some will run up to 160 or so. Guys working moonbounce (yes bouncing signals off the moon and back to earth) will run close to the max with large antenna arrays. Although moonbounce can be worked with 100 watts and 10 element beam if the guy on the other end is running a larger antenna array. The most popular mode is FM and using the thousands of repeaters installed and maintained by hams around the country. Every community has one or more repeaters, many linked over great distances.
James K0UA
/ Citizen Band radios? #31
This discussion reminds me of my grandfather urging me at about 8 years old to learn Morse code in order to begin the licensing process. I wish I would have had to focus back then to have stuck with it. I remember my grandfather speaking of his brother (great uncle) who was disabled thereby keeping him from serving in WWII, but he was able with his ham radio to allow folks to come from miles around and have contact with those stationed overseas. I can't remember his call numbers/letters, but he was quite well known over the waves.
/ Citizen Band radios? #32
No, you need a ham license...for 2m use. These days a tiny bit of electronics knowledge and a bit of time studying FCC rules, and can get a technicians ham license. For voice communications this gives you lots of options, and 10-100 times more power than any of the free services. Plus you can probably use some local repeaters that may have a coverage area of 30-50 mile radius... sometimes MUCH more.
If you don't want to get a license, there are a few frequency ranges that are usable without licenses in the USA.
11-meter (aka CB) 4 watt AM & SSB
FRS/GMRS 462/467Mhz 0.5 watt for FRS, 5 Watt for GMRS (GMRS requires a license... no test, just a fee)
MURS, 151 and 154 MHz range... 2 watt limit.... I hear in 2014 it becomes legal in Canada too!
All of these license free options are going to be short range communications options. Each system has its pluses and minuses.
I like FRS for short range (<1 mile) line of sight work. Good on the farm for house to tractor communication. Generally use AA/AAA batteries, and are inexpensive.
Here is a good discussion on the various license free radio options Spaniel Journal - Everything You Always Wanted To Know About Blue Dot Radios... But Were Afraid To Ask by Bill Fawcett - February 2005
/ Citizen Band radios? #33
Is there no mandatory knowledge of Morse code required these days? Please excuse me for asking what maybe is a dumb question.
/ Citizen Band radios? #34
Not a dumb question at all... The Morse requirement kept a lot of potential people away.
In 1991 the code requirement went away for tech licenses (entry level license), and for all licenses in 2007.
/ Citizen Band radios? #35
Dual antennas are only good on big rigs. They need to be 7ft or 8ft apart.
Dual antennae are funny. They are directional in the line of the antennae, so they give great coverage out to the side, and cut your coverage in the direction of travel, just the opposite of what people think. If you want to reach down the road in front of you, mount duals front and rear on a lumber rack.
Since cell phones and cheap FRS radios have come in, the CB band has cleared up nicely. In the '70s a CB was virtually unusable, but it's not hard to find a clear channel now.
/ Citizen Band radios? #37
You folks reminded me of the old base units that when you keyed in mike it make a noise like a door opening up---- Can't remember the names of those though. :(
Boone
/ Citizen Band radios? #38
I have one in the RV. Used it for years, now RV has a rodent nest on top of engine ;(. I would like to put the CB into my pickup. Haven't found the time or the right antenna yet. CB is real quite now compared to the 70's. Hardly ever hear anyone now.
/ Citizen Band radios? #39
I used CBs when we had our farm. i had one in 2 tractors and a base in the house. Now I have 2 that I can use in any vehicle since I have since got magnetic antennas and put "Lighter" plugs on them. i use them all the time when I am on an out of town job. I actually like using them now, compared to my dads back in the 70's, every one had one back then, like the poor mans cell phone:laughing: Now days its the truckers and hobbyist it seems, but the "waves" aren't as crowded as I remember.
/ Citizen Band radios? #40
How many people use one in their vehicle? Their home?
I recently purchased a Cobra 19 to play with. I used it maybe a week and realized it's low on the list of nice radios. I then purchased a Galaxy DX 949, which is 100X better. Since I was eager in getting a better radio, I didn't research enough on the actual sizes of each unit. My 949 is too large a frame to mount in my Tacoma decently. I've completed more research and have narrowed the field down to just a few radios that will fit my truck, and my wallet. One of these is an 'Export Radio'. As such, it covers many more frequencies and this is my question:
Can I use this daily as a CB radio only...legally?
I'm a HAM operator so I never needed a CB-if you can study a little about bands and some electronics you can get one easily. No morse code reuiments now and they eased up on what you can use a HAM license for now. You can even use it to remote control a device, or, order a pizza now :) I keep promoting the HAM because it's so usefull and the more licenses the harder it is for the feds to take our frequencies away for big corporations.
