What is the name of this key
   / What is the name of this key #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
We call it Bosch key and it was widely used in ignition switch for motorcycles, military trucks and tractors back in the day - like after WWII. With a bit of clever hands it was possible to use a nail instead:)
Was it ever used in USA and what is the name for it, please?
   / What is the name of this key #2
That looks vaguely familiar, but at the same time, I can't recall seeing one or remember what it was for.
   / What is the name of this key #3
Interesting , I have never seen that before.
Of course all that was before encoding and GPS tracking.
A fellow worker said his Father have a military jeep in Italy after the war and he needed a thieft deterent system. As it was stored at a mountain/ valley/ dead end road, he just removed the steering wheel.
Craig Clayton
   / What is the name of this key #4
Looks like what's used as a standard electronic jack-- for stereos, headphones (old style, for sure!), mikes, guitar amps & such. Maybe that was the beginning of the "standard"? I think we used to call them just "1/4 inch jacks."
Yes, I still use them! (And yes, there's a Dual 1019 turntable and a Teac 7" reel-to-reel deck attached to that Kenwood, all operational and often used!:thumbsup:)
   / What is the name of this key #5
Only key like that I have ever seen was used by Zetor.
One guy from motorcycle site knows:
it is called Bosch XOM1/XOM2 and apparently it was only on imports from Europe in USA. Makes it a safe lock for machinery now, doesn't it?
But it brought me to another question - was there ignition key for old cars? Say model T - did it have a keyed ignition?
   / What is the name of this key #8
In 1939 they had keys that just turned the ignition on and off. Stomp starter on the floor.
   / What is the name of this key #9
There were some much later models than that with the starter under the clutch pedal; just turned the key on and pushed the clutch to the floor.
   / What is the name of this key #10
I think my older brother had a Buick automatic that had the starter button under the accelerator pedal. You had to have the transmission in neutral/park, and then you pressed the accel. pedal to the floor to start the engine.
Prokop: Did that key have to be turned, or just inserted? Did you have a separate starter button? The indent obviously opened some contacts and gave you tactile feedback. Perhaps the flange below the handle fit into a slot that turned when the internal mechanism was at the proper spacing. When I see something like that, I just wonder how it works.
2001 CHEVROLET 3500 SERVICE TRUCK (A52708)
2001 CHEVROLET...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
HAY SPEAR, 3PT (A58374)
HAY SPEAR, 3PT...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
