New Firefox update 8.0.1 Beware
/ New Firefox update 8.0.1 Beware #1
Western
Super Member
Wise county Texas
Kioti DK 35 now
Since I keep my Firefox auto update set to manual, you'd think I would have been smart and checked the web for others responses to the update prior to allowing it to install, BUT NOOOOO. I updated and spent most of the day trying to find what the problem is and so are several other 1000 Firefox users.
I haven't had the crashes, but the constant hanging when loading pages, have to restart my internet connection to time it out.
The update also isn't compatible with allot of add 0ns and extensions and from what I can tell Firefox has left it up to everyone else to build around there tech. at least that's who they blame. Even Java console is incompatible if you use it. My Bitdefender anti phishing extension also is "incompatible"!
After going through all my add-ons and extensions looking for possible trouble along with making sure they where up to date, also trouble shooting Javascript errors now. I ended up going back to the previous version . It was easy, kept all my Bookmarks and is running great so far.
Just wanted to give fellow Firefox users a heads up, while YMMV, I would let them work the "bugs" out , check the peer reviews then upgrade.
/ New Firefox update 8.0.1 Beware #2
I've had problems with mozilla and IE, Google Chrome to me is the fastest and least troublesome out of the 3.
/ New Firefox update 8.0.1 Beware #3
Another + for google chrome.
I tried Chrome once, didn't take. I may have to give it another look if this keeps up. According to what I read today on various forums, is this is common on Chrome too, but persistent on IE. As far as update releases go.
/ New Firefox update 8.0.1 Beware #5
Updated to 8.0.1 on three computers over a week ago, not a problem with any of them. Java stuff has been broken for a while now, but I don't get any errors. All my pc's are 3 to 5 years old, but were pretty much top of the line spec wise when they were new. Hope this helps.........
/ New Firefox update 8.0.1 Beware #6
1) Know what you've got.
2) Know what you are doing.
3) DO READ the release notes
3a) DO UNDERSTAND the release notes.
4) See 1) above.
5) See 2) above.
6) Ta Dahh; No Problemo (-:
/ New Firefox update 8.0.1 Beware #7
I don't remember the last time I ever saw an "upgrade" as being better then what I'm using now... many year's ago, yes but I'll stick with Firefox 3.6.23 with ad blocker plus.
With google chrome, can you block the ads? (I wouldn't think google would not let that happen).
I'll also stick with 3.6 until the bugs get worked out. I'm sure there are many pc's that upgraded that don't have the problems, of course they usually don't go online and post a "success". Also I doubt there are 2 PC's exactly the same as how they may react to various updates. Either way it has issues and I generally never update without checking it out, but this time I dropped the ball.
/ New Firefox update 8.0.1 Beware #9
Im of the opinion...if it works well ... DONT EVER UPDATE. Nearly every time i had updated in the past i have made something else not work. Not worth the effort to mess with a good thing. Besides, every time you update they usually include garbage that you never wanted anyways...lots of useless and possibly invasive crap.
/ New Firefox update 8.0.1 Beware #10
I get no pop up ads with Google
/ New Firefox update 8.0.1 Beware #12
Popup ads are no problem, it's the reduced reading area with the side bar ads and extra "google" ads... Firefox on left, IE on right... They are put there with scripts that firefox simply can ignore and not load.
/ New Firefox update 8.0.1 Beware #13
weird, cause i have TBN opened up in both IE and Firefox, and the ONLY difference is in firefox i dont have the ad for JD right above my posts. Otherwise there the exact same. Im not sure how you captures your screen views.
/ New Firefox update 8.0.1 Beware #14
I'm running Firefox also, probably the latest update. I have had some strange things happen lately. I'll be surfing from one site to another and all of a sudden my machine shuts down... WTF? Anyway, give it a minute or two and it'll fire right up again although MS has a message that my machine shut down differently or something like that. I had no idea why and never give Firefox a thought. I wonder???
/ New Firefox update 8.0.1 Beware #15
...I'm not sure how you captures your screen views.
Hold down the shift key and press "Print Sceen" key ;) that's the one to the right of F12 on standard key boards. That makes a copy on the "clip board" (that you can't see) then I open a graphics program, "Paint" works fine but I use "Adobe Photoshop", Click on "File", Create or "New", and then on "Edit", and finally "Paste".
"Paint" program can do it but it doesn't crop well so I just outline what I want to keep and copy that into a new file. Attachment below is just doing it twice!
/ New Firefox update 8.0.1 Beware #16
Hold down the shift key and press "Print Sceen" key ;) that's the one to the right of F12 on standard key boards. That makes a copy on the "clip board" then I open a graphics program, File, Create or New, and then Edit, Paste. "Paint" program can do it but it doesn't crop well so I just outline what I want to keep and copy that into a new file. Attachment below is just doing it twice!
hmm, i tried it...nothing.
when i hit shift print screen, nothing happens.
i went to f1 help, i followed their directions...still nothing... hmm
/ New Firefox update 8.0.1 Beware #17
XP doesn't support the print screen function, or at least mine doesn't. I use this free program Prinkey 2000 for screen caps, lets you resize and save as whatever image type you need.
/ New Firefox update 8.0.1 Beware #18
mines win7, and according to the f1 help key it should. something im doing wrong
/ New Firefox update 8.0.1 Beware #19
update.. not that you care, but i did a google search, and found that i didnt have my f lock key engaged. its working now
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
International 490 Disc (A65640)
International 490...
Ditch Witch Mixing System FM13V (A65579)
Ditch Witch Mixing...
2026 Electric Tricycle (A64194)
2026 Electric...
2013 Kubota RTV 900XT (A64127)
2013 Kubota RTV...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
