sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,020
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
My work truck is a daycab Internation with a Cummins Red motor in it. They run them around the clock mostly six days a week, and the daytime driver got out of it the other day, and I got it, after checking it over and headed down the street. Got a half mile down the street and heard a pop. Sounded like a hose clamp on the turbo went, allowing the hose to come loose (or a hose blown). Turbo sound changed at that time also. I pulled over and inspected the clamps/hoses to no avail. Guy from next door (Big truck and trailer parts supplier) had been standing out front when it "popped" and came over to tell me he thought the turbo just went, and pointed out the smoking stack. I called dispatch, who told me to bring it back and change trucks. So I drove it 15 mph back to the yard, but when I turned into the driveway, it acted funny, like it wanted to not slow down. I pushed the nuetral button (automatic tranny with a clutch) sending it into nuetral gear as I rolled into the yard. The engine slowly started to build rpm's and I reached over and hit the key, but with no results. Tried the key off/on a couple of times before realizing that wasn't helping. Hit the "D" to get it back into gear hoping to stall it via braking, but it wouldn't go back into gear due to the rpm's (has to be at idle for it to go into gear). Smoke filled the air like I have never seen, and it went skyhigh in rpm's before going "bang" and shutting off.
I have heard horror stories of diesel with machanical pumps going into run away mode, but never late model (2005) with a computer controled brainbox.
My thoughts (or wild guess) was that maybe the turbo blew a seal which allowed the pressurized oil from the engine (that cools the turbo) to be mixed with the diesel fuel in the combustion chamber of the engine, until it got going enough that it started running off the oil as a fuel which prevented it from shutting down, and literally gave it unlimited fuel to send the rpms skyward dispite the computer having max guidelines set in it. I haven't heard what the shop has decided as of yet and since the shop they use can't change a battery holddown bolt correctly, I doubt I will ever know the real picture.
Anyone have any ideas of what could have happened?
One scary day, no doubt when your unable to control something as powerful as one of these trucks. Things could have been a lot worse than just blowing a motor!
David from jax
David from jax
