boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,829
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
Get a big @$$ hammer drill from a rental place and set anchor bolts or threaded bar into it or angle iron. Either cement them in or use epoxy then either bolt the post down in some way or weld it to the angle you put in there. I think renting a drill and welding would be cheap. Course this assumes you have a welder and you have a generator to get power to the field, and that you can weld.
what i thought of first as well.
you can rent the large concrete drills. with "whole saw drill bits" for rock / concrete from the rental place as well.
normally the drills have a garden hose hook up, due to the need for water to keep the wholesaw bit cool down as it drills.
once drilled down so far. you would need a wedge or something to pop the core back and forth to break out the piece. so you can drop the post down into it.
a hammer drill. with a smaller masonary bit can work as well. but would advise if buying the actual drill, is go with something in mid range pricing vs cheapest thing out there. and buy a couple extra bits.
the one problem you may face long term. is water getting down into holes, then freezing / expanding, and as a result cracking of the rock. and fence post becoming loose. or possibly falling over.
if electric fence is being setup. you my take some 5 gallon buckets, or sono tubs or other. and fill them up with concrete. and before concrete dries drop a piece of rebar into the bucket.
not a permanent solution. but more about keeping the post standing up and not falling over in winds / rain / snow.
other option, instead of having posts go into the ground. each post = X or A frame like setup. so fence can not fall backwards or forward.
