M series assistance please
/ M series assistance please #1
bunchgrass
Gold Member
N. Idaho
Kubota 8540
First, I should have been posting under this Kubota heading instead of under the General forum - my apologies to those who've already seen some of my questions.
I'm looking at buying a Kubota M series tractor and am considering the M7040 vs M8540. I run a hay and cow/calf operation so plenty of loader work.
Need: loader, pallet forks, 3rd function remote for loader (runs hay grapple)
Options: cab vs ROP w/ canopy, 2WD vs 4WD, Special Utility (SU) series vs standard 'M' for 7040.
Want: to keep price below $40,000
Your opinion(s) on what options are must haves vs expendable. Example = 2WD vs 4WD.
/ M series assistance please #2
Where are you located. What type of hay (small squares / rounds / silage ). What hay equipment do you have ie disc mower etc.
Assuming you have a small mounted disc mower and handle dry rounds, any of the M's over 50 or so hp can do the work. If running a disc mower conditioner you need the larger M's, maybe even a 96s or 105s.
If you ever think you may sell it, get 4wd. 2wd tractors are hard to sell and take a big hit on depreciation. Having a 4wd its hard to go back to a 2wd, at least on a loader tractor. In muddy seasons its so nice to feed without having to chain up and put thousands of pounds of ballast on the rear.
/ M series assistance please #3
If you are going to use the tractor you want the 8540 with cab, wheel weights, and 4wd. The cab will be appreciated whether cutting hay when its 105 degrees or feeding hay in the snow and sleet. The 4wd will keep the tractor moving with a full loader or in bad conditions. The wheel weights provide better traction pulling or pretty good loader capacity without a rear attachment.
I run a 9540 and it is large enough to pull most round balers and sub 12 foot cutters to provide a backup to your primary hay tractor. I also moved the rear wheels to their widest setting and the tractor feels much more stable and confident.
@slowzuki - we're in Idaho and do small squares and use and accumulator and grapple setup (ie 3rd function on loader) as well as have small cow/calf operation. I agree with the 4WD assessment - nothing worse than a loaded bucket on a slick slopes.
Part of my concern w/ cab and larger tractor is the need for ability to get around in tighter spaces (ie. pens and sheds) w/o tearing off the roof (of either the cab or my shed). Might be worries about nothing - you know like the first scratch on a new car!
/ M series assistance please #5
If you spend a lot of time in sheds you will want an open tractor, but I know how hot it is in parts of Iowa in the summer and a/c is really nice.
You'll probably want something around the 7040 or larger size. The 96s and 105s are going to be tight inside buildings.
What tractors do you have now? A lot of people will keep an old 135/165 MF or similar for scraping out pens with a box or rear blade and raking while having a larger machine for mowing and baling.
Oh slowzuki! I'm in Idaho not Iowa - but I can excuse your knowledge of US geography since you're Canadian:D Sadly, here in the states Idaho is often mistaken for any other "I" state by US citizens. No wonder we have an inferiority complex!
BTW - it does get hot here in the summer too. Does the canopy provide the same clearance/visibility issues as the cab does? Or are those even issues?
Right now I have, and am always working on, a MF 265 w/ beat to helk loader. I'm able to think about upgrading because even my wife is feeling sorry for me with my current tractor - she said you spend more time under it than on it:confused2:
/ M series assistance please #7
If you are only working square bales and need to work indoors you definitely do not want the 8540, it is larger than the 7040 in every dimension and you do not need the extra capacity.
If you are working indoors, you may want to consider the Grand L series along the lines of a 4740 or 5740. They have the 3rd function, have enough power for a square baler, are much more maneuverable than a 7040, and the HST transmission is a great help in close quarters loader work. It is also lower and shorter than the 7040.
I use an open cab 4630 for woods and close quarters work and it will run circles around the 9540 when power and capacity are not an issue.
/ M series assistance please #8
Hi bunchgrass.
My situation may be similar to yours. Run a small cow/calf operation. I feed round bales but still store some in sheds that are real tight to move in and out of. That and costs kept me from getting a cab tractor. I figured if I didn't tear it up in a shed I would hang it on a tree when pulling firewood.
The tractor I use for those chores now is a M7040 with mechanical shuttle. Rears are filled and set out as far as possible. I mow hay with a 8' disc mower and roll with a 4X4 new holland baler. The tractor handles a 10' draw bar rotary mower just fine. Nothing heavy, just pasture chipping. I put a canopy on mine and it makes a difference in the hay fields.
I have little over 1400 hours on this one with no problems to date. Have a smaller tractor for tedder and rake and cleaning out barns etc. Hope this helps. Good Luck.
/ M series assistance please #9
My situation is somewhat similar to yours. I have a small cow/calf operation. I'd planned on getting a L4740 or L5740. The HST is super nice on those tractors. Both would have fit with 5-6 inches clearance under the pole barn that I clean out in the spring every year.
OTOH, the M7040 offered a larger tractor with much more loader that I could grow into and would be particularly useful when I moved to a larger property.
For me a cab was a must this time around and would bite the bullet and do the cab for sure. Now that I have had one, hard to imagine life without it. I can be out in inclement weather that I would otherwise stay in during. Important for me as I have little time on my hands and like to get things don when I have the time.
I don't think you are going into any really small buildings with either the L5740 or M7040 with a cab. One wrong turn and I think you are going to really damage the cab. If you get a cab, you will have to keep low hanging branches trimmed. I embarked on a branch clearing project with a rental pole saw - got it done in a few hours. I will have to do that every year.
I also recently purchased a MF 255 to spread manure - no loader - and I think I will use this to clear the pole barn. You might want to consider keeping your MF 265 around for this as well. I might even consider making some changes to my building so I can get in with the larger tractor - however I won't be turning around anywhere.
BTW: While I do like the hydraulic shuttle on the M7040, I don't think it will compare to a HST for precise loader work. I'm far from being over the learning curve but it has practically been like relearning to use a loader in a pile of manure. The HST stops on a dime. Maybe the M7040 will as well some day but I doubt it. I'm getting better everytime I use it. Something important to bear in mind if using the loader is your primary function.
/ M series assistance please #10
I am in a simiar cow calf set up and looked at new tractors in this size range and thought about the m7040 NewHolland Workmaster 75 and John Deere 5075E and ended up getting the John Deere 5075E this fall with 553 loader skid steer quick atatch bale spike and 3in 1 loader bucket no cab. It is much heaver than the m7040 at over 9000lbs with loader weights and rimguard more loader capacity and seems more stable with a round bale or bucket full of dirt. I only have 20 hours on it so far but I am very impressed with it and have no regrets in my choice. I got the whole set up with 2 remotes in the rear and 1 on the loader 2 sets of wheel weights and rimguard inthe rears for $36000. I think it would be woth your time to check it out. I use my L3400 with loader for cleaning the pens it is just the right size.
/ M series assistance please #11
Sorry that was just a mis type. Ment Idaho, and it was 35 C both there and in Washington in September. (I think thats near 100 f?) We drove from there to Fort MacMurray Alberta the next couple of days where it was snowing. I'm from a potato producing area so I expected that not the arid desert like conditions we saw!
/ M series assistance please #12
I've had the same requirements as well. My solution was the NH TN75DA which is 75hp ( engine) with a cab, it's a low profile cab and I can fit under anything a ROPS fits.
I use a bale accumultor and grapple as well which I really like because it make hay a one man operation.
Personally, I think a cab is a must to work a full day and be comfortable, to mow and be out of the dust and insects, to be out of the heat etc etc etc.
How much hay are you going to cut and what shape are the fields. Will you ever round bale? Are you likely to upsize the operation, stay the same, or down size?
For square baling only, the Kubota Grand L series would work very well. Think about slowing down, turning corners etc. I happen to use a sickle and have to do a lot of shifting, same when loading the trailer with the bale grapple. A hydrostatic tractor would make this a thousand times easier. Raking and tedding too.
I don't think the cabs are that tall and you would likely get used to maneuvering them very quickly. yes, occasionally the cab is in the way, but I have a smaller 30hp utility tractor for that stuff.
One more thing, how picky is your baler about speed? I borrowed an M7040 from a friend of mine once to bale with. I hated it. I was used to a 12x12 transmission with a lot of speed choices. His tractor only had an 8x8 and I was able to go too fast or too slow for baling. Either an HST or a 12x12 would be much better. 16x16 is great of course.
One advantage of the Grand L's would be a tighter turning radius over the M's at a slight sacrifice in ride smoothness.
Lot's to think about....
Well here's the deal in front of me .... Dealer has 8540HDC on the lot and is motivated to move it. Like $45,000 with cab, loader, 3rd function etc. That's about 15% off MSRP as I calculate it and is the same price they ask for a 7040HDC. Still, that's a lot of dough. My other options now seem to be OPEN STATION 8540HD @ ~$40,000 and sane on 7040HD @ ~ $37,500.
I know we've been round and round about cab vs no cab but is that 8540HDC @ $45,000 really that good of a deal? Or could I likely work 15% off MSRP on any of the other models (not currently on the lot)? Thanks for hanging with me on this as it's close to decision time.
/ M series assistance please #14
15% is a pretty good discount. Many figure 10% to be more typical, but you'll never know if the equivalent deal is available for the other units until you do some haggling. The 8540/9540 owners will give the best comments about the tractor itself, but from what I've read, they are excellent tractors.
/ M series assistance please #15
Hard to pass up at that price! Up here in Canada I paid $46k for a M7040 with a cab and hyd shuttle.
/ M series assistance please #16
I just configured the 8540 HSDC with the self leveling loader, side defogger, rear wiper, radio and air ride seat for $56,579.00
Granted what you are looking at may not have each of these options but it looks like they are offering you a pretty good price - if that was with a loader.
Nice tractor that would do a very nice job for you. Again, do you need that much horsepower and the associated fuel consumption? I'm having the same discussion as I have downsized from 100 to 40 acres and am not really convinced i need the NH anymore.
/ M series assistance please #17
Lots of good opinions here.
I purchased an M7040SUD last year. I use it primarily for slightly different things (moving dirt, working in the woods, clearing snow). I don't bale with it. But I'm very happy with the tractor. Going that route, I was able to save quite a bit of money over the fancier versions of that tractor, or larger models. I don't need all the bells and whistles and the technology of the tractor is straight forward and time tested (not that it'll never have a problem).
When I purchased it, I compared it to the JD 5075E, similiarly priced. The base machine for JD is a bit heavier. But the layout and basic touches of the Kubota are better (solid semi-flat floor, instruments, hydraulic clutch on pto, telescoping stabilizers to name a few). I also like the loader on the Kubota better, it's heavier and offers separate power and height settings configurations.
I'd go with the 4wd version of whatever you get, if you live anywhere traction can be an issue (wet ground, slopes of any sort, snow, etc.). I previously had a 2wd and it was much easier to get stuck. And with a loader, 4wd can be incredibly important. With a full load, the back tires will not get great traction on sloped ground, even with substantial ballast. 4wd makes all the difference.
Good luck with whatever you buy!
/ M series assistance please #18
I thought that was what everyone did. Maybe your wife and mine need to have a chat. I would like a new tractor too.:D
Seriously though, I would definantly go with the 8540. More loader capacity, larger, more stable machine. My dad has a 9540 open station 4wd. It is great for the cutter and baler. I would ask about the 12 gear option instead of 8 though. I think it may be something the dealer can install. He does not have this, and it would help to have more options sometimes when running the baler. I guess it would be nice to have a cab, but i aint paying for it he is. I did not get any say so. We bale in Louisiana without it though. I guess a little sweat and dust never killed anyone.
/ M series assistance please #19
That is a good price and about what we paid for our M8540 HDC. We didn't get the third function valve, but got the same size tires as the 9540. It is a 12F/12R which we really would recommend.
We are very happy with it and the limited slip front differential is a real improvement over the Case CX80 we traded in, we have not gotten it stuck yet, but got the Case stuck in the same areas.
The 7040 is a really nice tractor, but we preferred the 8540 for the 12 over 8 and we did not want to go down in HP.
I wouldn't even consider an open station, but many prefer them.
/ M series assistance please #20
I owned an M8540 HD open station for a couple of years. It's a great tractor. It's a not very common model around here. I had the FWD and FEL. Great tractor. Plenty of power. I recently sold it and bought a 9540 HDC with FWD and FEL with the air ride seat and cd player. I am enjoying the cab already from the dust and heat. However, if you do a lot of work where you are on/off the machine, the open station is much easier. The visibility is better on the open station but overall I think the cab will be the way to go for me. Plus you can enjoy listening to the radio.
Caterpillar TL1055D (A62177)
Caterpillar...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
