HELP - Utility lines next to Stumps & the driveway!
   / HELP - Utility lines next to Stumps & the driveway! #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I'm not sure this is the correct place for this post, but here goes.
Finally the Utilities got out here to mark the buried lines. All there is out here is electric and phone.
The #$%^&ing utilities trenched heir lines one on each side of the drive, and on on each side of the loop. The electricity line actually crosses under the driveway to change sides TWICE!!! I want to know who the drunk was driving the trencher...
Regardless, along the edge of the driveway, where the pasture is going in, there is a line of pawlonia stumps that are going crazy sending our runners and making life TERRIBLE. These trees are invasive and fast growing. Think crab-grass & dandelions crossed with an Oak Tree.
So approx 6" off the driveway is the phone line, and within approx a foot is the centerline of the stumps I need to grind (which is also just about the intended fence line for the pasture!!!!
What can I do! there is some rule about within a couple feet all digging must be by hand tools!
These stumps MUST GO!
Do I call the utility and ask them to remove the stumps? or to move the line?
I am not using phone service, but I might in the future, and I do NOT want to break their line.
This stinks.:thumbdown:
The power line is also in terrible spots. I cannot build my Motorcycle shed by the gate because the power line runs right through that spot, and at an agnle so it kills that whole 25 by 40" space...
Thanks in advance,
David
   / HELP - Utility lines next to Stumps & the driveway! #2
I would call the utilities out and see if they have a solution, they may offer to help, or tell you your on your own.
Either way you'll know exactly where you stand
   / HELP - Utility lines next to Stumps & the driveway! #3
If you are just grinding the stumps down to a few inches below grade you should be OK. The electric SHOULD be trenched in a couple feet underground and well out of the way, and they usually put the phone line in 18" or so... Probably would cost you big bucks to have them come out and re-locate your underground electric... they would probably just abandon the old wires and trench in a new feed. You could never dig up the old lines without damaging them. Good luck.... Jerry
   / HELP - Utility lines next to Stumps & the driveway! #4
Hand dig on top of the marks to verify they are correct and find the depth of each. Once you know the depth and that the marks are correct then you can dig with machinery knowing you will not hit the line.
I use a RD 7000 on some job sites that can actually tell you the depth of the line as well as locating it. Depending on the burial type (direct buried vs. conduit) the power should be 24-36" and the phone should be 12-24".
   / HELP - Utility lines next to Stumps & the driveway! #5
Another thought.
Depending on your planning horizon, you could stop regrowth using the cut-stump method -- make a fresh cut across the top of the stumps and then spray or brush on 41% glyphosate (generic Roundup), either undiluted or diluted up to say 25% with water or diesel fuel. Then wait for the stumps to rot. There are products available that are supposed to accelerate rotting -- I haven't used them and so cannot comment on their effectiveness.
Steve
Jerry & Dmace,
The depth of the phone line is the key I agree.
Is there anywhere to find "code" info so I can make a guestimate on depth?
I'm moving the shed location. I need to do some site prep now, but such is life. The fence line I can move slightly, but the stumps have got to go...
Thanks,
David
Another thought.
Steve
Steve,
My reading on Pawlonia is that the poison method does not always work. It is an insidious species, with aggressive runners. The very first stump I ground was a Pawlonia and the side runner is growing like mad right on the cut edge.
I already have runners sprouting 15 and 20 feet away and the trees were cut down last November...
I HATE these trees with a passion...
David
   / HELP - Utility lines next to Stumps & the driveway! #8
Another thought.
Steve
I assume that this is your own private drive and these are the phone and electric that feed only your house? If so, don't even worry about the phone. If you cut it, and you want it later. Just call the phone company to hook you up. When they come out to do so and test the line, they will find something wrong and install a new faster better quality line at their dime. Just play dumb.
Now as far the electric. Do you know if it is primary or secondary? Do you have a big metal box up by the house that has a little hum to it? If so that is a transformer and that means that is a primary (i.e. roughly 7200 volts). DON'T HIT THAT ONE!:D It should be 3'-4' deep if it's not real rocky. Regardless it should be in conduit and at least 24" deep, secondary and 36+" for primary and you should be able to grind the stump with no concern.
Removing the stumps is possible, but it will be like removing a brain tumor. Slow and careful and lots of hand digging. Good luck.:thumbsup:
   / HELP - Utility lines next to Stumps & the driveway! #9
Do a "cheat" grind on the stumps, this only takes them down only 3" below ground, from there spray roundup, add soil and seed. 3" should be a safe depth and new soil and a new seed bed on top should make them a memory.
High Compression,
Yes this is my private driveway.
I am totally staying away from he electric, and YES I have a big green High Voltage box up by the house. So this is SERIOUS voltage line meandering around my driveway... Great...
Something the widow said back when I was buying this place makes me think the electric is not in conduit (unless those orange plastic ones could be used.
The phone line is my issue now...
David
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
