So called "tool box"
/ So called "tool box" #1
Dead Horse
New Hampshire
On the Kubota tractors HAVE to be the worst designed, most useless, annoying piece of engineering about the WHOLE tractor.
There......... I do feel better.............:D
/ So called "tool box" #2
I feel your pain. But I also feel the pain of the designers when they try to find a place to put a decent sized toolbox. I recently picked up a 30mm ammo box at a flea market for a few dollars. It's big enough to store two big or three small cats! But trying to figure out where to attach it has got me stumped. Every time I think I have a good spot it creates some unintended conflict - blocks view of 3pt or PTO, can't raise/lower ROP, interferes with FEL, etc, etc. I'll figure some way to mount that sucker, just not before I relocate the lights on the rear fender (which lights I tore up in the woods within 90 days of taking delivery of TOM (The Orange Menace).
/ So called "tool box" #3
I had an L2900 GST before I purchased my current tractor and was never able to find a way to mount a decent toolbox. The one that was on it was really worthless and if you put anything it, it was impossible to open it. The one that came with my current Kubota, MX5100 HST, is a little better, but not much. However, the way it is mounted on the tractor I think I can replace it with a much larger one without interfering with anything. I have ordered a 20" toolbox from TSC. They offer two sizes, a 20" and a 16" and as far as tractor toolboxes are concerned I believe I need the largest that will fit somewhere! Here is a link to the page with the toolboxes. They are overpriced, but my wife, an Ebay Queen, thoroughly reviewed the offerings there and nothing beat the price at TSC and some of the offerings look like they were made at the old Belarus plant!
Search Results
You may have to copy and paste for the hyperlink to work.
/ So called "tool box" #4
Wow yours lasted 90 days, you must of had the good plastic:laughing: I lined mine with styrofoam, and drilled a hole in the bottom. I can keep two beers cold for up to 3 hours.:D I just walk back to the barn for tools, that way upon my return to the tractor I will be somewhat dehydrated:thumbsup:
/ So called "tool box" #5
I would be leary of buying any tractor that came equipped with a tool box nicer than the tractor.:laughing:
/ So called "tool box" #6
Any solutions for a BX25 thats big enough to hold a grease gun?
I cant even find a decent mounting place. ROPS is out as i need to crawl through to get to the BH.
/ So called "tool box" #8
Here are some pics of my "tool box". Also good for adding some extra weight to the back of the tractor, as well as towing stuff.
Eric
/ So called "tool box" #9
Hmm...pondering the need to store several cats on my tractor.
:D
They are always around when I'm working outside. The mice and chipmunks have no hope now. The big gray one (13#) has no teeth, but that doesn't stop him. The little one (7#) is fearless and she's a great producer. I always like using cats as units of measure. In this case, volume. Another example: "it was so close there wasn't enough room to swing a cat".
/ So called "tool box" #10
I have the T1530 and most the time have the brush hog on the back, so I keep a over-sized milk crate between the support bars.
In it I have a large bucket with the tools and things I need for the chain saw, a 1 gal gas can, 16 chainsaw which tilts up and I put other items under the bar.
Also in another link here is a great description and pic of a roll bar mounted box.
http://www.tractorbynet.com/forums/customization/7218-toolbox-new-holland-tc40-tc45.html
/ So called "tool box" #11
The grease gun could be mounted in a 12inch piece of pVC pipe mounted horiz somewhere on your rig. The hose would be outside like the handle or tucked back into the top of the pipe?
/ So called "tool box" #12
Ive seen that trick before (and the store bought equivalent holders).
2 problems for me are
1 the lack of clear vertical space to mount the grease gun holder (rops and area by the 3pt is out)
2. i want something enclosed to both protect the G Gun and tools from the weather.
I havent seen a solution really. Mostly due to the small size of the BX. Mounting a toolbox to the bucket lift arm mount (like on traditional large tractors) would almost get in the way of the bucket :laughing::p (I exaggerate a bit, but its a small machine :))
/ So called "tool box" #13
Here is what I did on mine. Two boxes made from a PVC fencepost with caps. The second is a piece of PVC pipe put through the hole in my loader arms.
/ So called "tool box" #14
OK, so what am I missing? I grease up before I go out why do you want to carry the grease gun throughout the day and where will you keep the extra cartridge?
Am I not greasing frequent enough?
I do like the fire extinguisher holder.
/ So called "tool box" #15
mostly just to keep the gun and a small tool assortment on the machine. My machine gets moved around a bit, having the gun and some tools on the machine means it'll be there when you need it.
/ So called "tool box" #16
Nicely done
/ So called "tool box" #18
It's probably not a big deal if you only use your tractor at your place. I have three different pieces of property that I take care of though, and sometimes the tractor will be away from my home for weeks. That's when it would be handy to have things like the grease gun and often used tools actually mounted on the tractor. I have yet to find a solution that really fits my needs though, because a lot of the property I mow is wooded and those limbs really like to rip things off the tractor. For now, I just have a big portable tool box that I labelled "tractor" and keep all the stuff I think I'll need in it. When I take the tractor somewhere, I take that box with it and just leave it there until I bring the tractor back. Still not as handy as having it mounted on the tractor, but at least I know that most of the tools I'll need are just a few minutes walk away.
/ So called "tool box" #19
I feel your pain, the Kioti toolbox is a complete JOKE also.
/ So called "tool box" #20
My wife ordered the Tractor Supply toolbox for me as a birthday present and I installed it today. I must say it worked, fit, looked better, and was heavier than I thought it would be. It was a fairly easy install and only took about an hour. I made a couple of modifications and improvements that made it even better. They offer it in two sizes, a 16" and a 20" and your toolbox can't be too big, so I asked for the larger one. They are both the same price anyway. I lined the bottom with a 1/8" rubber pad and put weather stripping inside the lid where it meets the sides of the box and then cut off the little carrying handle on the box after I ran the tractor for awhile. I was attempting to limit metal-to-metal vibration noise (aggravations). And, it worked. It is black, but close enough to Kubota gray that I am not going to repaint it. I took a picture of the worthless OEM toolbox and my new TSC replacement. It really worked perfectly on my MX5100. The kit included several types of mounting brackets and thumbscrews to secure the box to the brackets. There is an indented area for the thumbscrews. The kit is well thought out and easy to install. I still have full view of the 3 point hitch and attachments and plenty of seat room with the seat moved rearward. For my applications this is a winner and reasonably priced.
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
1992 Rammax Trench roller and Extra Set of Drums (A62613)
1992 Rammax Trench...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
