Texas Heat!
/ Texas Heat! #943
I think I heard a propane tank explosiong this morning around 5am. I also heard the helicopters this morning fighting the fire. The wind is still calm for now.
/ Texas Heat! #944
Also, if the contract was canceled just for maintenance reasons...............why hasn't a new contract with another operator been signed.:confused3: They are more than one fire bomber outfit out there.
hugs, Brandi
It is fire season, all the other firefighting aircraft are likely under contract already. TX would still have to make an interagency request for firefighting resources to get these aircraft. The way the article about Boise NF sending trucks and crew down was written it sounded like that just happened. Dunno if that is true or not.
/ Texas Heat! #945
I know states on the east coast have been sending foresty crews out as aid. I am surprised they do not have the national gaurd involved. I am sure the governor of Texas (Perry was the main supporter. Google it.) is regretting his support on cutting the funding to wildfire study and aid. Have you all been taking pictures?
Eddie,
Aircraft that are fire bombers are subjected to more structural stress than an airplane that flies point A to point B. Also the chemical retardants they carry can affect the structures. Like making hay, they go all out in a short period of time. In the haste, scheduled inspections and maintenance can get short changed. I can see the Forest Service stopping contracts easily for a maintenance program that is found lacking.
Now, I wonder why the Forest Service stopped the contract and flying now, just when Texas needs them. Could it be that obama really doesn't like Texas.
Also, if the contract was canceled just for maintenance reasons...............why hasn't a new contract with another operator been signed. They are more than one fire bomber outfit out there.
hugs, Brandi
They are getting very strict on these plains. They have had a lot of line of duty deaths due to these plains crashing. It is the same with ground operating fire apparatus. Also, there are not that many contractors across the US that fly for wildfires. There has been a lot of agencies calling for assistance in coming up with a better plan for wildfires. The governent response as I said above was to cut back its funding and let the fires burn. The problem is when you let a fire burn it gains speed, volume and eventually makes its own weather which makes them unpredicatable. It may not be a threat now but three days later it is in position to devastate an urban area. If there would have been action taken in the begining there would have been a lot less chance of the effect snowballing.
Stay safe and hope things get better for everyone.
/ Texas Heat! #946
I just found this map online that shows the extent of the main fires.
/ Texas Heat!
Caught a little of the news early this morning before passing out. They said they have the aircraft, but not the qualified pilots? (thinking out loud) Seems to me a stealth bomber pilot could work in a pinch, they seem pretty da## "qualified" to me! :D and been putting out "fires" for over 10 years:thumbsup:
I know there is probably "more" to it, but you'd think someone could step up to the plate.
Also, I don't think Gov. Perry, or anyone else for that matter, could have predicted this drought and the conditions that came with it, well maybe Al Gore.
/ Texas Heat! #949
Austin news, sports, weather, Longhorns, business | Statesman.com
the pilots have to be certified on the specific plane.
another pilot was grounded with mandatory 2 days "off" for having worked to many hours.
also ive watched the number of houses burnt jump from 300-600 last night to, i saw 1600+ reported this morning.
/ Texas Heat! #950
"Feds take control of Bastrop wildfire, then turn away volunteers"
Firefighting-trained volunteers from all over the state converged on Bastrop and Smithville on Tuesday to aid worn out firefighters battling the Bastrop County Complex Fire - - only to be turned away as federal offifials arrived at the scene and took command.
Complete story here:
Volunteers upset after being sent back home | The Gonzales Cannon
/ Texas Heat! #952
It sounds like it was the Texas authorities who turned them away, which was the correct action. The incident commander has to maintain control of the response, and they don't need a bunch of amateur yahoos running around creating problems. If the volunteers were NIMS (National Incident Management System) certified, they would have known how to offer their services, and known that they would have to be a part of the chain of command.
There are online courses listed at FEMA | Federal Emergency Management Agency Many of them are applicable to volunteer organizations like churches, food banks, etc.
Specific to Texas, check out https://www.preparingtexas.org/ViewCourse.aspx?courseid=402f88cb-2f13-4627-82ab-8fe44fb10502 and https://www.preparingtexas.org/ViewCourse.aspx?courseid=a903a479-726c-4a11-a8c6-b03cc7eeb56f
Anyone trained in NIMS knows FEMA doesn't "take command." Command rests with the Incident Commander until relinquished, and the Incident Commander is normally the first on scene.
/ Texas Heat! #954
and they don't need a bunch of amateur yahoos running around creating problems. .
There are many, many, many highly trained volunteers thru out the US... in this bad situation no firefighter should be turned away.
Call one of them a yahoo to his face.
/ Texas Heat! #955
Yes, but you do not self respond to a fire, with no apparatus.
That would be like me driving my personal vehicle from here in N Calif, to one of those big fires that happen in S Calif. I have the gear, but no engine. And no support.
That is why we have strike teams. In my area, the strike teams are made up of Battalion Chiefs and engine companies from the local fire districts, including volunteers. For any given week, certain engines and crews are on call for strike teams.
While these guys intentions were good, they should have been on engines, and informed the state fire service and local commands before they headed out.
/ Texas Heat!
Not to throw "fuel on the fire" , but you kind of have to know the Texas area mindset, we are kind of an independent "get ""r"" done" sort, so when something major happens like these fires, anyone that can, tries to help.
At the Palo Pinto fire and I'm sure down in Bastrop, folks that can't physically help, or are in evac mode are/where supplying cold drinking water, meals and cots where needed for the firefighters. I am sure most of them "get in the way" at times. DPS and SO usually do a great job with crowd control and send folks the right direction.
Not much you can do when mother nature is in charge.
/ Texas Heat! #957
Dennis,
Your so right. It's being a Texan with our independent spirit. Over here in the Montgomery and Waller County line fire, they are using individuals with tractors to cut fire lanes. I would definitely be there with the Big RED Beast if I hadn't had knee surgery yesterday morning. So saying if you don't have a vehicle that squirts, go home, is a ridiculous thing to tell aTexan. We don't like waiting for help. We help ourselves.
hugs, Brandi
/ Texas Heat! #958
We don't know if they were NIMS certified, we do know they were trained firefighters - However there is no state minimum standard training for Texas firefighter volunteers. I guess they figured the Bastrop fire trucks can work longer hours than the firefighters can stay awake so to help their fellow Texans they came to give them a break to get some rest. That is all.
But Perry did call the Feds. FEMA is now paying for it so they can make the rules.
/ Texas Heat! #959
Western, Brandi, I understand the sentiment. Fortunately, that level of get involved is seen in other parts of the US too. We see people get involved like that here. It is a great part of the spirit of the US. My family, and others in our Scout Troop jump in and help too.
But, the Fire Service has standard procedures for responding to a fire. Driving 2-6 hours in a personal vehicle, and asking to be put on an assignment is not one of them. That is how people get hurt or killed; there are reasons for those SOP's, for paid and volunteer firefighters.
Those SOPS's include staying in the chain of command, so appropriate resources can be sent where needed, and can return home safely to their loved ones.
/ Texas Heat! #960
Don,
Isn't that what firefighters do when they go to a funeral? Other department' firefighters man the absent fire fighter's equipment?
Have you talked to Mike lately? We would like an update on his house and his FIL's house.
hugs, Brandi
