blueriver
Super Member
- Joined
- Oct 4, 2007
- Messages
- 5,012
- Location
- S.E.Oklahoma
- Tractor
- JD 5520 Montana 4340 Farmall Super A Montana 5720C
Okay today I bled out all the water, started with 28 psi in the tank, turned the pump on and no change. So I thought the tank/bladder is bad, so I decided to remove the tank. When I took the line apart it was loaded with sand. I cleaned it put it back together, started again with 28 psi and lots of pressure and lots of dirty water ... I quess this well is bad ???
