1910 completely rolled over
   / 1910 completely rolled over #1
pclausen
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
I don't know if the engine kept running for a while after it flipped over, but after the tractor was rolled back onto its wheels, there was oil everywhere.
Do these old tractors have any sort of engine cut-off when they roll over? My concern is that if the engine kept running, the oil pump would have started sucking air within seconds I would think. It would probably have taken a minute or more before the engine would have stopped from the fuel pump sucking air.
I figured I should at least change engine oil and filter, and check the coolant level before attempting to start it again. Anything else I should check?
Tragically, the operator died in the accident, which was not discovered until several hours had gone by. The red engine kill knob had not been pulled. The ROPS had been removed years earlier as the tractor would otherwise not clear the garage where it was kept.
   / 1910 completely rolled over #2
Sorry for the loss of the operator. I'm not aware of any tractor with a roll over engine kill switch other than the standard operator presence switches in the operators seat. Be sure and check ALL fluids, including trans. I would consider barring the engine over by hand before hitting the switch, in case it filled the cylinders with oil or fuel. Don't want to cause damage if we can help it.
   / 1910 completely rolled over #3
It's possible for engine to be hydro locked from oil on top of pistons. I would suggest pulling injectors to save bending piston rods.
Thanks guys. I'll check all fluids before proceeding and pull at least one injector. I'll start by taking off the loader so that I can better get to things.
   / 1910 completely rolled over #5
Are you keeping this tractor or is it going for resale?
Am I the only one here that get's a queasy/weird feeling over owning a tractor someone got killed on?
   / 1910 completely rolled over #6
Pull the engine over by hand,,hydro-lock can do quite a number on the engine with the starter...Sweep, I have never noticed a sign on the seat saying the last soul that sat there had expired? Seriously, If I knew the person, yes, it might make me sell it...I've had one neighbor shot and killed, it is not the best feelng in the world, either..
I checked the fluids and coolant looks good, but the engine oil dipstick is dry.
Here are some pics of the poor thing:
It looks like a lot of engine oil made its way up under the hood when it was upside down. Looks like the area between the fuel tank and head is where it came from.
I don't plan to keep it. The operator was my father. It was pretty tough pulling the bush hog off and the FEL and getting the thing into the shop just now. The accident took place Saturday. I was the first one at the scene after my mother found the rolled over tractor when he didn't come up for lunch. He had been dead for hours at that point.
A couple of friends came over yesterday to help me get it loaded onto my trailer and hauled off my parents property so my mother wouldn't be constantly reminded of the accident.
The best way I know how to deal with tragedies like this is to try to stay busy...
   / 1910 completely rolled over #8
So sorry to hear about your father. I can't imagine going through what you have gone through.
Staying busy does help.
   / 1910 completely rolled over #9
So Sorry , that you had to go thru this chore..Yes, stay busy and try to keep mom occupied, maybe out to supper...
   / 1910 completely rolled over #10
So sorry to hear about that. I couldn't walk anywhere near that tractor had that happened to me.
My prayers are with your family.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
6-Row Narrow Cultivator (A52128)
6-Row Narrow...
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
