Packing crate on pickup truck?
   / Packing crate on pickup truck? #11
If I had to do this, I would rent about a 14' truck and a car dolly for the Tundra, which the truck can easily tow.
Take it all in one fell swoop, and you are safe and legal in all states...
   / Packing crate on pickup truck? #12
I made a set for my truck. I made a front that matches the sides, and bolt together.
A few times we have had long distance Scout trips for camp. Everyone else took cars. I took my truck, and carried all the boys stuff(backpacks, duffel bags, tents, sleeping pads. We have a Troop trailer with all our patrol boxes, cook stuff ect. It has lots of room for the boys stuff. But, we didn't need it, and in Calif, even though I-5 is 70mph, towing speed limit is 55mph. It was easier for the trip from near Sacramento to San Diego(Camp Fiesta Island is AWESOME if you're a Scouter!) to just take the truck and load it up.
I used 1x6 to make the sides, 18" tall. Trimmed down 2x3's for the stakes. Used the same for the front(I bolt the front to the sides with "L" brackets). I can tarp it if needed. Between the 8' bed, and the sideboards, I can fit a lot of stuff.
How about some racks using the stake pockets and cover the front and top with a tarp.
   / Packing crate on pickup truck? #13
Charles, moving to more acreage? Taking the tractors, whats going on? :confused3:
   / Packing crate on pickup truck? #14
I'd vote for sides built up off the stake pockets... Less Lumber, More cubic feet. I'd also suggest you build a sloped overhang. You can create a little more space and improve your handling and mileage.
I worked for a moving compay for two summers in college. You can fit a ton (literally) of stuff in a truck like this if you do it right. Pack in similar sized boxes if you can. Put heavy, sturdy stuff on the bottom and lighter stuff on the top. Load your truck in tiers. Make a row going side to side accross the bed. Fill it all the way to the top and then start another row. Load so the face of the row is flat and then stuff little stuff behind to fill in the cracks.
   / Packing crate on pickup truck? #15
My impulsive sketchaholic tendencies prevailed, and I've drawn a picture to illustrate my point about the sloped front. I really don't think it would be hard.
Build a skeleton like this...
Then skin it with OSB or plywood like this...
If you made the sides 4 feet high you could use full sheets of plywood on the sides without having to cut them. Or is your bed shorter than 8 feet?
moving to warmer weather, getting too old for the cold.
So for ease of construction and rainproofing I just built 4x4x8 boxes, with rain detailing. gives me 256 cubic feet, which should take care of a lot.
Great sketch though!
for those curious - plywood box in utility trailer worked really well. And tightly packed, held an enormous amount of stuff
   / Packing crate on pickup truck? #18
Take it slow and cautious. I know here in Calif we can only go 55mph with a trailer anyways. Not sure in the area you're going.
That is funny!!:laughing::laughing::laughing:
Last November I pulled a trailer from AZ. To Washington state and stopped off in LA to see the grand Kid and Family. I was being passed by atv haulers, camping trailers, and boats like I was standing still and when I looked down at my speed odometer I was only doing 75mph. Going North on I5 was the same story! It might be posted 55 but nobody reads them! Now going to LA I went thru a high wind area and all the haulers slowed down there to about 40mph for about 35 miles!:D
   / Packing crate on pickup truck? #19
I think Curleydave has the right idea, determine how much space you need, rent a U-Haul box van with a car dolly. Load your pickup with items unaffected by weather or tarp items in the pickup bed, load everything else into the van and head South. You are going to spend a lot of time and money on fabrication of something that may or may not serve the purpose then be stuck with a big wooden box after the move. If your pickup has a towing package you might want to consider finding a used 6x12 or 14 used tandem axle box trailer, make your move then sell it. I still think the box van and dolly rental is the safest and easiest method. Good luck.
Unused Delta Crash...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
