Price Check L4740 HST Quotes
/ L4740 HST Quotes #1
schnejerator
Middle of MD
Kubiota L4740-3
Hey all,
About to pull the trigger on an L4740, and just wanted to share the first round of quotes.
Prices are for the HST w/QA 72", R4 tires, LA854 loader... No extra remotes or anything.
Dealer #1: 27,400
Dealer #2: 29,500
Dealer #3: 28,500
The second dealer gave me some attitude when I told him he was $2k higher.
Any prices on similar equipment appreciated. Thx,
Jeff
/ L4740 HST Quotes #2
I have recommended going to Barlow Tractor Package Builder and contacting them for a bottom line price to find out what kind of deal you are getting. Barlows will quote you a price delivered. Worth the effort for the info if nothing else. Who knows you may end up buying from them. I did.
/ L4740 HST Quotes #3
Are they all quoting same bucket? There is standard duty square back and heavy duty round back. I would get at least one remote to operate a hydraulic top link. Philip.
/ L4740 HST Quotes #5
/ L4740 HST Quotes #6
Agreed, a minimum of one rear remote, we got two on our last tractor. A hydraulic toplink is very helpful on hookup and in use.
/ L4740 HST Quotes #7
man those are some high prices.i got a mx5100 hst w/la844 fel for $24,000.so if i was you id price on the mx5100 hst.those prices are $3000 to $5000 higher than what i gave.
/ L4740 HST Quotes #8
Hi there Philip...I have 2 rear remotes on my L3830. What does a hydraulic top link like that cost, (about), and do you have a part number? I think I will get one.
/ L4740 HST Quotes #9
This. Philip.
Philip, what do you find the need or benefit for the hydraulic top link? That hitch has a rating of 2700 pounds plus of lift and was wondering what would be needed for that. Does it apply down pressure with ground engaging equipment?
/ L4740 HST Quotes #10
With hose kit you are looking at $250. Here is link, Tractor Hydraulic toplinks, Top-N-Tilt, Side link cylinders. I eventually replaced straight connectors on cylinder with 90 degree connectors, could not find pics of this. If you buy through ccm, they will also want hose lengths. If you tell them ahead of time they will put banjo fittings on cylinder, which is better than the 90 degree fittings I am using. Philip.
/ L4740 HST Quotes #11
It makes it easier to hook up equipment, you dont have to screw the oem link in or out. Also, you can adjust angle of equipment (grader blade, box blade, auger, etc) as needed from the seat. It does not apply down pressure, your lift arms will float up. You can really pivot your mower up for blade sharpening without having to slide underneath. Philip.
/ L4740 HST Quotes #12
Wow! Thank you Philip! I will be ordering one. However...what is a banjo fitting?
/ L4740 HST Quotes #13
Like what you would find on a brake caliper. It is a 90 degree fitting, thru bolt with center drill, and two sealing washers. Google may give better description and picture. You will thank me again after you use it a few times, trust me. Philip.
/ L4740 HST Quotes #14
Also very handy for backing onto a slope, easing into heavy brush or for transport.
/ L4740 HST Quotes #15
Thank you Philip for your information...and I learned about banjo's!
/ L4740 HST Quotes
Good call on the buckets - $400 difference (MSRP). Quotes all just said 72" QA bucket which could be any of them. Should've gotten DETAILED quotes.
And that hydraulic top link is brilliant. I will be adding remotes myself - can't handle paying what the dealers ask, and even if I try to have them "throw it in" feel like I'll be paying for it (was quoted $800 for 1 set). The 3rd function will also be down the line, maybe a WR Long or similar upgrade.
How do you feel guys about filled tires? Seems to me there are better (and more flexible) alternatives to adding weight.
jeff
/ L4740 HST Quotes #17
How do you feel guys about filled tires? Seems to me there are better (and more flexible) alternatives to adding weight.jeff
I like weight, but I like to remove it when not necessary. A heavy implement or ballast box does the trick. Philip.
/ L4740 HST Quotes #18
Same here. Your response time goes down with loaded tires also and will effect fuel consumption when it is there and you don't need the weight at the time in addition to the hassle of having to fix a flat if needed. It's a whole nuther undertaking with filled tires where without you fix it with a repair plug kit on the spot and don't have to pay for the the fluid of choice as well not to mention what it would take to put it in.
/ L4740 HST Quotes #19
jeff
For our bigger tractors, we use filled tires and weight. We find filled tires add stability on slopes. Wheel weights/cast centers work fairly well, but cost a lot more.
No question that tire repair is harder with filled tires, but for us it works well.
/ L4740 HST Quotes
Told 'em to scrap the filled tires. I like having the option.
And buckets are the same - 72" squareback.
Thanks for the input - will probably be making a decision tomorrow after a little more negotiation.
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
2014 International DuraStar 4300 S/A Dump Truck (A61573)
2014 International...
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
2022 EZ-GO ELITE...
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
